Old 01-28-2009, 11:05 PM   #1
drewfever1020
my fuel pumps clogged
whats the best way to unclog my fuel pump?
drewfever1020 is offline   Reply With Quote
Old 01-28-2009, 11:18 PM   #2
sjarrett71
sjarrett71's Avatar
Re: my fuel pumps clogged
Are you sure it's your pump and not a line? I'd start by replacing the rubber lines if you haven't done it already. If it is your pump, just replace it, they're less than 20 bucks from what I remember.
sjarrett71 is offline   Reply With Quote
Old 01-28-2009, 11:31 PM   #3
cdowns
cdowns's Avatar
if your fuel pump is clogged you've got bigger problems than just changing the pump
it's time to remove and clean the tank
Old 01-29-2009, 12:54 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have never heard of a (mechanical) fuel pump getting clogged.
Why do you think that's whats wrong? There's a screen in the tank, a filter in the carb, possibly another filter inline, lots of rubber than can be swollen and not letting enough fuel through, could be crap in the tank or in the carb....
Old 01-29-2009, 09:53 AM   #5
68gmsee
Active Member
68gmsee's Avatar
Another thing to check:
On my 68 I replaced all the filters and fuel pump and found that the metal fuel line going from the tank to the fuel pump was so restricted due to rust and buildup that fuel wouldn't come out.
I replaced it with one from the autoparts store and placed a filter under the cab after the fuel tank. I replace the filters about every 3 months.
68gmsee is offline   Reply With Quote
Old 01-29-2009, 01:44 PM   #6
tim21391
tim21391's Avatar
i would try taking the bowl off the carberator. my truck i had the tank in and out since im doing work to the body...and i couldnt get my truck started...so i thought it was the fuel pump and was getting ready to get a new pump..then i took the bowl off the carb and wiggled the needle/float or whatever it was and boom she fired right up and ran perfect
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
