Old 01-29-2009, 12:21 AM   #1
hchad18
hchad18's Avatar
Ride tech tubular lowers and a sway bar
I bought my tubular lowers a year ago and am now looking for a swaybar. The musclebar swaybar from ride tech is $400.00. Well I cant do that and I've found this one http://store.summitracing.com/partde...5&autoview=sku in another members post for $180 something shipped. Problem is its 40.5" center to center (hole to hole) and the mounting holes for the ride tech lowers are about 47". I can either cut the tabs off the tubular lowers (powder coated) and re weld or possibly re bend the swaybar to make work. Any suggestions other than buy the musclebar?
hchad18 is offline   Reply With Quote
Old 01-29-2009, 11:44 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Ride tech tubular lowers and a sway bar
Nathan Porter from Porterbuilt Streetrods told me that he can have a custom bar bent for less money than that one from Summit. I think they were from Hellwig? I would give him a call and see if he can help you out.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-29-2009, 01:15 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
I have the front sway bar for the Ride Tech lower control arms...would you be willing to do a trade if you already have the sway bar? I need a sway bar with the 40 inch mount spacing for a customer project, and I'm just about to order one. If you don't already have the sway bar, I can sell you mine. Let me know. Thanks.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-29-2009, 01:25 PM   #4
jlaird
jlaird's Avatar
I am interested if hchad18 passes on the deal.
josh
jlaird is offline   Reply With Quote
Old 01-29-2009, 04:16 PM   #5
hchad18
hchad18's Avatar
I've ordered it and I'll have it on the 2nd of February, I am interested.
Old 01-29-2009, 09:07 PM   #6
p8ntballer1911
Bodydropped71
p8ntballer1911's Avatar
Are you planing on getting really low? Like laying frame? I had those arms and mine being z'd those arms were way to close to the ground.
p8ntballer1911 is offline   Reply With Quote
Old 01-31-2009, 06:27 PM   #7
hchad18
hchad18's Avatar
No just bags, no cups and 2.5" dropped spindles. Its close but not that low.
Old 02-01-2009, 01:37 AM   #8
PBFAB.COM
PBFAB.COM's Avatar
I can get you a 1.125" bar for $200 shipped. If you have the "new" style ART lowers (the ones that have the shock mounting tab pointing up) it will fit like a glove.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-01-2009, 08:55 AM   #9
jlaird
jlaird's Avatar
Originally Posted by porterbuilt View Post
I can get you a 1.125" bar for $175 shipped. If you have the "new" style ART lowers (the ones that have the shock mounting tab pointing up) it will fit like a glove.
Does that include endlinks and mounting brackets?
Old 02-01-2009, 12:22 PM   #10
hchad18
hchad18's Avatar
The shock mounting tabs point up, but the swaybar tabs are horizontal to the ground and are about 47" center to center. 175 is with the end links and brackets?
Old 02-01-2009, 01:19 PM   #11
PBFAB.COM
PBFAB.COM's Avatar
Yes. That includes the end links and brackets.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-01-2009, 02:06 PM   #12
jlaird
jlaird's Avatar
Who is the manufacturer of the bar and the hardware? Could we buy just the bar? I'm thinking about getting those AirRide end links instead of the standard bolt/bushing/spacer setup.
Old 02-01-2009, 02:47 PM   #13
hchad18
hchad18's Avatar
This other guy might want me to trade, let me see where he is at first.
Old 02-04-2009, 03:01 PM   #14
PBFAB.COM
PBFAB.COM's Avatar
I had to make an edit to my earlier post regarding pricing on the bar. I was given some misinformation and they will be $200 shipped. I have sold a few at the $175 price, and am working with a couple more that WILL recieve that same price.
Also, I can get pretty much any eye to eye width necessary, just PM me for pricing.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-04-2009, 06:12 PM   #15
lolife99
67-72 parts collector,…
lolife99's Avatar
I will be in touch,...
Keith
Convert to disc brakes.
