how to make my truck ride smoother?
I took a 150mile round trip in my 84 today. It rides like crap. How can I get it to ride smoother like my old 99 CK ex-cab? My 84 has stock suspension for now and I`m not sure about the shocks but they are about a year old. Any suggestions? I do have a 3/5 drop I wanted to install but I don`t know how that will effect the ride quality.
Anthony |
One shot, one kill.
Re: how to make my truck ride smoother?
Tony, you don't say if the 84 is FWD or not. If it's FWD there isn't much you can do except pad you seat better. 2WD you can change springs and get a softer ride that is close to late model but you'l never match it. A late model LWB rides like a car. Even the FWD models and thats all front suspension. There are no springs in the world that perform like torsion bars do. Thats why they use them on the M1A1 Abrams. Just get used to a truck that rides like a truck.
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
Happy to be here
![]() Join Date: Mar 2000
Start with looking at your entire suspension. Does it need rebuilt? Are the bushing worn? What shocks do you have? What tires are you running?
If you have worn suspension components, too stiff a shock, or tired sagging springs it will have a negative impact. No matter what, it's still a truck but you can improve on quality if you focus on the problems and make improvements as needed.
It`s a 2wd truck. It could probably use a rebuild but the inner & outer tie rods, pitman arm, steering box and front shocks were replaced in Dcember of 2007 according to the paperwork I got from the PO. Steers great but it could probably use bushings and ball joints as well. I don`t know what shocks they used but I plan to get some dropped shocks when I lower it. The ride wasn`t too bad and I can live with it but I know it could be better. I just didn`t know if there were any tricks to make it ride smoother.
Anthony |
SWB trucks ride stiff anyway but worn suspension components make it worse. If you plan on lowering the truck set aside some cash to rebuild the front suspension as well. There are several companies that offer complete rebuild kits that include all bushings,rod ends, ball joints...etc. I rebuilt the suspension on my old truck and it made a world of difference to me. When you lower the truck it will handle different anyway... lower center of gravity.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
2WD 4 Life
mine always rides like a caddy with a good load in the bed
Big D 1969 c10 1960 cadillac 1978 king cobra |
you might try taking a look at the A-arm bushings and see if they are worn out....they usually make a big difference.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles ![]() '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L ![]() ![]() ![]() |
you could ride around with about 1200lbs in the back. When ever I had about 1200 lbs in my old 77, that thing rode like a cadillac...lol
Another option is to check your cab mounts. if you do replace them, or any other bushing on the truck, use only rubber parts if you want a good ride. Last edited by 78 Chevyrado; 01-29-2009 at 06:56 PM. |
Thanks guys. I`m going to save my pennys and replace the control arm bushings and the ball joints when I do the lowering kit. Thats the only thing that wasn`t replaced a year ago according to the paper work.
Anthony |
In the Forgotten far North.
![]() Join Date: Jul 2007
air bag it.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
Anthony |
#12 | |
profeshinaly unimployed
"having mud flaps is like asking for a smaller trophy" |
#13 |
I've been pondering this as well. My 78 Big 10 is just as rough as that Abrams tank. My favorite gear-head bar-stool advisor is telling me to replace all the suspension bushings with new polyurethane for starters, and then OEM rubber bushings for the cab.
Never having done any of that, I wonder how hard it is for a moron like me? A Saturday job? A weekend job? I haven't looked it up in the service manual yet, just wondering what the group's experience has been like.
1978 Silverado Big 10 - "The River Runner" 1969 GMC C/10 - "The 2008-09 Winter Project" |
#14 |
truck addict
hell if its never been done.. bolts are seized and a pita to get off... i have recently ripped the whole suspension off my 87 c10 2wd.. i am bagging mine but when i did drive it i could feel a hair when i ran over it.. all the bushings where shot thoughout the whole truck including the cab mounts so there on the lsit as well
trucks |
#15 |
If you have never done suspension work or don't have the correct tools it can be a pain in the ass. You may have to heat the control arm bushings to get them out. I've had to burn some of the bushings out with the shop torch instead of pressing them out. Poly bushings have been known to make noise when flexing.
#16 |
Most add a couple 50lbs sand bags or they sell a big bag you put water on.These trucks where designed to ride smooth fully loaded empty they ride rough.
#17 | |
#18 |
the pollock
anyone going to mention TIRE PRESURE?
heheh that was my issue
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
