01-29-2009, 03:35 AM | #1 |
1-ton (D60?) SRW vs. DRW Front Axle
I looked around and didn't find anything that answered my question directly.
I have seen two 80's crew cabs for sale locally. Both are 1-tons (K30/K3500, Chev/GMC). I am assuming these should both be D60 front axles if they haven't been swapped through time. What is the difference between the two; the one for a single rear-wheel application and the one for a dual rear-wheel application? Is one better than the other, can the DRW version be converted to SRW easily?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
01-29-2009, 04:34 AM | #2 |
Re: 1-ton (D60?) SRW vs. DRW Front Axle
they are essentially the same axles, but the drw has the wheel mounts out 4" wider on each side through the use of a different hub body, and the rotor is held on with bolts instead of being clamped in place by the wheel studs.
if you are planning on running rims with a lot of backspacing (like humvee double beadlocks) then the wider stance of the drw axle will help. to convert to srw hubs is usually sort of pricy.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
01-29-2009, 11:41 AM | #3 |
The only difference between the 2 is the hub and rotor assy.
01-29-2009, 01:19 PM | #4 |
Thanks for the replies!
I would like a crew 4x4 but really don't want the dually. Sounds like I might be money ahead looking at the SRW then?
01-29-2009, 04:57 PM | #5 |
In House Collision Technician
thr rotor bolts to the hub. u can remove the bolts, drill the holes for normal wheel studs & then have the hub itself turned down on a lathe to remove the area where the wheel original mounted. i've had this done by the local machine shop & it ran me 175.00 dollars. it still comes out cheaper than swapping the hubs & it kinda looks cool having a machined looking hub versus the cast look.
MAXIMUM DESTRUCTION |
01-30-2009, 12:27 PM | #6 |
I know a guy that did that and he hates it but the damn srw stuff costs so much to convert.
