01-29-2009, 09:19 AM | #1 |
12 Bolt Axle swap
If I keep the 12 bolt axle in my 67 chevy I want to change it over to 5 on 5 . Has anyone done this and can point me in the direction of a company that has axles that are strong enough to take some abuse and maybe share some part numbers. Keep in mind that I will be refitting with disc brakes as well.
Thanks for any help. |
01-29-2009, 11:41 AM | #2 |
1970 Daily Driver
Re: 12 Bolt Axle swap
CPP has the conversion axles you are looking for. They are $289.00 for the set. I will post a link.
http://www.classicperform.com/Store/.../6369RAC-5.htm Summit racing may have them as well at a little cheaper price. I got 5 lug conversion axles for my 70 from summit but I had the longer axle and could use the stock 71-72 Axles. They may have the shorter conversion ones you are looking for as well, I would give them a call or check their website for sure. The ones for my 70 were $99 a piece with no shiping charge. If they have them it would save you around $100 as CPP charges shipping. Summit has a cheap Rear Disk Brake Kit as well. This is the one I am looking at myself. http://store.summitracing.com/partde...0&autoview=sku
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 01-29-2009 at 11:53 AM. |
01-29-2009, 12:58 PM | #3 |
Thanks a ton. I appreciate the info.
01-29-2009, 02:16 PM | #4 |
1970 Daily Driver
Here are summits 5 lug conversion axles. $144.69 A peice. They are a stronger hardened axle. I am not sure if CPP's axles are or not, I would check. With out shipping charges summitt would still save you some green.
http://store.summitracing.com/partde...5&autoview=sku
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
02-12-2009, 02:49 PM | #5 | |
Doug Looking for a 67-72 short bed driver..... |
02-12-2009, 02:58 PM | #6 |
1970 Daily Driver
No problem, The ones I just put in my truck looked and fit great.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 02-12-2009 at 02:59 PM. |
02-12-2009, 03:55 PM | #7 |
i have a complete currie 9in but i know they do 10-12 bolt also. call them up. i remember ordering my axles 5 on 5 and was questioned about it. guess most people go for 4 3/4. i have 31 spline extreme alloy and ran me $340
Here is their 12 bolt axles..http://www.currieenterprises.com/ces...E.aspx?id=1770
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. Last edited by ripdog28; 02-12-2009 at 03:55 PM. |
