Bodydropped71
What fittings do you use?
I have some brass compression fitting I am using now but i really don't like them very much. I feel the quick disconnects are safer. My brother has the quick disconnects and I am leaning more toward those. What is everyone else running?
It'd be alot cooler if you did
Re: What fittings do you use?
Nothing quick about what I'm running.. JIC fittings.
67-72 parts collector,…
![]() Join Date: Nov 2002
I like brass DOT fittings. Usually Parker fittings.
Look at your local Fastenal Store. They ordered mine and had them in in 2 days. They also stock the black "plastic looking" fittings,... but I don't think they are DOT.
DOT approved Push-to-Connect stainless fittings from Parker Hannifin
Brass DOT PTC fittings.
depends. dot ptc brass for the daily and anythin i run under 200psi.
compression fittings for the hopper (~400psi). i feel safer with those, and my local fitting place doesnt carry anything over 1/2 for ptc. i also run hydro hose before the valve. |
GM ONLY BABY!!!
All brass sealed up with white pipe cement. I got mine from a local big rig supply shop, or NAPA.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
I like Nickel Plated ASCO Push To Connect fittings. Otherwise I like to run hardline with a 37 degree flare or double flare fittings and aluminum or stainless line.
If you can find it cheaper, I can fix it! |
86 C10
i have both on my truck ptc and compression was using all ptc but redid my rear setup and the only thing that i found near by were compression fittings.
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold ![]() |
