Old 01-29-2009, 10:24 AM   #1
70GMCer
70GMCer's Avatar
FS Lokar Shifter & Switch
OK, it is now up for sale. Sold as a set, (Shifter & Switch) Will not separate. Price includes shipping.
Here's a Lokar shifter linkage part #ACA-1800 & a Lokar backup/neutral safety switch part #BL-1400U. These parts where on my 70 and are setup for a sbc with 350 turbo trans setting in the forward V8 position on the frame. This setup is fully adjustable.
According to the instructions, I had to cut about 1" off the shifter rod for fitness. Also had to bend the rod for clearance, just like the factory setup has.
If this would fit other setups, I cannot say, but I don't see why it wouldn't. Go to http://www.lokar.com/ to see applications.
I have a copy of the installation instructions for the shifter linkage, but not the switch. Easy though. All you do is remove 2 bolts in the trans oil pan & replace with the provided spacers & bolts. The switch lever makes contact with the shifter lever at the trans.
I only have around 200 miles on the shifter linkage & have "never" wired up the switch. The switch was just mounted on the transmission pan. All parts look like new except where nuts have made contact with washers & shifter arm.
Keep in mine that the switch can only be used for either backup lights, or neutral safety switch. You can't do both at the same time.
$40 SHIPPED in lower 48. Paypal for payment.
Please reply to post. "Brad" has 1st dibs
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-29-2009, 01:20 PM   #2
Brad
Out of the carpool lane.
Brad's Avatar
Re: FS Lokar Shifter & Switch
Consider it sold. I'll respond to your PM.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 01-29-2009, 03:03 PM   #3
my67chevytruck
Under Construction
my67chevytruck's Avatar
Great deal......
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-29-2009, 04:58 PM   #4
70GMCer
70GMCer's Avatar
Sold to Brad
1997 GMC Sierra Ext
1965 Mustang
