Old 01-29-2009, 11:17 AM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Front Suspension Questions
With my rear almost done on my 82 swb, I need to start looking at the front 2wd conversion. 1st Question: What, if any, are the differences between the years(73-87) front suspension wise? I also plan to rebuild the front while I'm there, do I use rubber bushings or poly? I want a nice ride and I am also getting the 4"/6" Western Chassis Economy drop kit at the same time to avoid pulling the suspension apart twice.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 01-29-2009, 02:27 PM   #2
Cherub
Cherub's Avatar
Re: Front Suspension Questions
Id replace all the rubber bushings with poly, wont have to replace them again for a while if not ever.
Cherub is offline   Reply With Quote
Old 01-29-2009, 03:37 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Are you wanting differences in all 4x4 suspensions between 73-87 or the differences between 4x4 and 4x2?
The actual 4x4 hanger pieces are virtually the same on all 4x4s.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-29-2009, 05:35 PM   #4
softballnrd27
No, I am wanting to know if there is any differences between the years for front 2wd suspension. I know what I need to finish the 2wd conversion I just want to make sure all the years from 73-87 will work and there are no major differences.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 01-29-2009, 05:46 PM   #5
flamingbig10
6.0 powered square
flamingbig10's Avatar
there the same
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 01-29-2009, 05:56 PM   #6
Captkaos
Captkaos's Avatar
2WD is the same as flaming stated. They are essentially the same from 67-87.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-29-2009, 06:03 PM   #7
softballnrd27
OK, just making sure. Thanks guys
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 01-30-2009, 07:51 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Not all are exactly the same. There were light duty (1 inch thick rotors) and heavy duty (1 1/4 inch thick rotors) brakes. The earlier years all had the HD brakes. Later years had both. Definitely get one with the thick rotors.
