Registered Mail
I am bagging my truck at the moment, but I wanna know how low I car drive it, until bump steer becomes a problem (or start happening?).
I am setting it up so that the control arm will touch the ground when deflated, so i figure I'll drive the truck with the front crossmember about 4 inch off the ground, will I have bump steer problems with that setup? arms, crossmember, and mounting locations are all still stock. but I do have drop spindles installed.
'67 chev 496, lwb to swb, bagged - pro street project |
Happy to be here
![]() Join Date: Mar 2000
Re: What height does bumps steer become an issue??
For safety, I suggest you set it so the lowest part of the truck is no less than 3/4" off the ground. Imagine blowing a bag or line at 60+mph. If your suspension makes contact with the road, it's not going top be a "controlled skid".
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-29-2009 at 12:44 PM. |
It's Better With Nitro
It's not so much the height of your vehicle as it is the steering arm geometry. If your steering arm is on the same hoizontal plane and remains parallel to the lower control arm through your designed suspension travel, there will be minimal bump steer - this is independent of the ride height. Do you have a photo of your steering arms in relation to the lower control arms?
Registered Mail
I could set it up so that when deflated it will be 3/4" from the ground, that sounds like a good idea.
but as far as geometry, well its all stock other then drop spindles, so the angle of the upper ball joint is still quite sharp when sitting at my wanted ride height. what causes the bumpsteer? the upper balljoints angles I thought? I just figure that since there are a lot of guys out there that still use factory arms, that maybe there was a ride height magic number that bumpsteer starts happening at.. I'm sure there is... (since the angle of my arms would be the same as all the other stock arms guys out there). ??
'67 chev 496, lwb to swb, bagged - pro street project Last edited by smoknbarrels; 01-29-2009 at 02:40 PM. |
#5 | |
If they're not on the same plain, they will be swing on different arcs as the suspension compresses/extends. The result is the steering wants to pull/push when the suspenion is cycling through its travel. You hit a 'bump' in the road, the suspension compresses, the steering & lower a-arm are @ different plains so they're fighting against each other which 'steers' the truck in the process.... ala 'bumpsteer'.
#6 | |
![]() Join Date: Aug 2006
I am no expert just have learned stuff along my journey to learn everything ![]() Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
Damn Scoti replied before i was done writing my book
Yeah, but I didn't provide the PowerPoint presentation..... Nice job BTW.
Thanks scoti!
If Your suspension is set up properly... Bump steer will never be an issue, no matter how hi or low you are, or how much suspension travel you have... I fabricated my own front suspension, I have 14 inches of travel.. and less than 1/32" bump steer through the entire suspension arch.
Tags |
bumpsteer |
