Old 01-29-2009, 03:49 PM   #1
Stock72c10
classic=of recognized value
Stock72c10's Avatar
Cost to replace a head gasket on a 250?
I have been having a terrible time trying to track down a bad oil leak on the passenger side of my inline 250. I have replaced the side covers/side cover gasket, valve cover gasket and still it leaks. I now think the leak is coming from the cylinder head gasket. A local guy estimated it will cost $500-600 for him to replace it. Does that sound reasonable? How much more should I spend to have him just rebuild it while he has it torn down (bored out .030" over?). Your opinions are appreciated. I am planning on dropping it off after work tonight for him to look at it to be sure it is the head gasket.
Stock72c10 is offline   Reply With Quote
Old 01-29-2009, 03:54 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Cost to replace a head gasket on a 250?
On an inline 6 like that, I get 100 dollars labor plus the gasket. Figure 150 total including new antifreeze.
It's a 2 hour job if you work at it.
Old 01-29-2009, 04:05 PM   #3
tim21391
tim21391's Avatar
i replaced head gaskets on my dads 67 mustang that has a 302 in it...it took me 8 hours to complete the task... it was my first time doing all that so thats why it took so long to clean up the old gaskets and such.. but the head gaskets, intake gaskets, and valve cover gaskets and adhesive cost me around 40 bucks...
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 01-29-2009, 06:47 PM   #4
Wrenchbender Ret
Its highly unlikely to be leaking oil out the head gasket on that engine. Wash it down real good & run the engine while you watch where its leaking. That price sounds high but it would be hard to find someone to do it as cheap as TX. I beieve the flat rate is about 4 hours. Most shops are getting $50-$75 an hour now.
Wrenchbender Ret is offline   Reply With Quote
Old 01-29-2009, 06:52 PM   #5
68gmsee
Active Member
68gmsee's Avatar
If you have any mechanical ability, they're fairly easy to replace providing you also have the proper tools.
As far as cost, $500-$600 sounds sorta high for just replacing the head gasket. Now if he was going to include a valve job and reworking the guides etc. then it would be somewhat more acceptable.
I had a complete head rework done about 10 years ago for $150. I also had the engine rebored and with parts and all it came to about $350. However, I took the engine to the guy already out of the truck.
68gmsee is offline   Reply With Quote
Old 01-29-2009, 07:50 PM   #6
Tx Firefighter
On an inline 6, all you have to do is unplug the plug wires, unbolt the exhaust flange, drain the coolant, and disconnect all carb stuff.
You don't even have to disturb the intake/ exhaust manifold gaskets, reset the timing or any of that foolishness.
It really is a 2 hour job. Nothing like a V8 with distributor and intake manifold fiddling.
Old 01-29-2009, 08:05 PM   #7
mr48chev
mr48chev's Avatar
Most good mechanics won't take much over two hours to swap a head gasket in this engine if they have the tools that help speed up the job. As TX Firefighter said you can lift the whole assembly off and save a lot of time. It helps to have a cherry picker to help lift it though.
You might try re torquing the head and see if that helps before pulling it off.
Old 01-29-2009, 10:56 PM   #8
Elephanthead
That price is high, the dealer would probably be cheaper. I did this when I was 14, it is not that bad of a job, but I am not sure that is your leak problem.
Elephanthead is offline   Reply With Quote
Old 02-03-2009, 11:02 AM   #9
Stock72c10
Stock72c10's Avatar
Turns out it wasn't the head gasket but was actually the diaphragm on the fuel pump was worn out and causing the leak at high RPM's. Never would have guessed the fuel pump would cause an oil leak. I guess I learn something new every day
Old 02-03-2009, 12:02 PM   #10
68gmsee
Active Member
68gmsee's Avatar
Just curious: How did the oil get from the fuel pump to the lifter covers or head? Was it blown up there?
If there was oil coming out of the fuel pump it seems it should have been very obvious. From my experience, fuel pumps don't function very well when the diaphragm is leaking.
Old 02-03-2009, 12:24 PM   #11
Stock72c10
Stock72c10's Avatar
I was told the fuel pump has a hole drilled in the side of it that allows the diaphragm to "breath." When the pump spindle seal wore out the engine oil leaked from this hole and the fan blew it back over the passenger side of the engine and all over the firewall. It only leaked at very high RPM's and not at idle, so all I ever saw was oil dripping off all over the passenger side of the engine. I should have the new pump in Thursday, so I guess we will see.
Old 02-03-2009, 02:58 PM   #12
68gmsee
Active Member
68gmsee's Avatar
Wow! No wonder you weren't able to detect it. That's one I've never seen before. Thanks for posting the solution.
