01-29-2009, 06:00 PM | #1 |
Calling all smoothed firewall
I am interested in doing this on my project.... I searched and couldn't find a real good place for info... I would also like to move the booster off the fire wall if possible.. like i said i could find exactly what i was looking for thanks
1970 Chevy X 2 2002 Chevy 1500HD 1990 Dodge Ram 50 (Gas Gitter) |
01-29-2009, 06:10 PM | #2 |
Re: Calling all smoothed firewall
Installing a Hydro Boost setup would remove the booster from the firewall.
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
01-29-2009, 06:44 PM | #3 |
Here is a pict of mine hope it helps..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
01-29-2009, 06:55 PM | #4 |
here is one that im currenly working on for member 71 hulk, its smoothed and symetrical....the master cyl. is under the dash with a mounting bracket i made and a 90* pedal assy.
01-29-2009, 07:09 PM | #5 |
Not a firewall but how about a smooth cowl/kick panel. This is rob32472's. Check out his build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=317665 Last edited by ebfabman; 01-29-2009 at 07:09 PM. |
01-30-2009, 09:21 AM | #6 |
I still have the booster, but here's how mine is.
01-30-2009, 07:09 PM | #7 |
wow... thanks guys... looks SHARP... 68 short step is that going to be a boosted setup??
01-30-2009, 07:22 PM | #8 |
Champagne Taste on Beer Budget
So I have a question for you guys with the shaved firewall setups.
Did you do away with your heater all together? I would like to have this nice smooth look on mine but still have at least a heater and possible an A/C setup later.
Coming Soon: Project 1970 Country Truck |
01-30-2009, 07:36 PM | #9 |
We sell these for 67-72 trucks if interested they are 18 guage
01-30-2009, 08:22 PM | #10 |
mbgmike, Is that a replacement or an overlay?
01-30-2009, 08:29 PM | #11 |
They are replacements but kind of both. There are actually 4 pieces to them. the firewall and floor pieces are replacements but the piece that goes on the cowl above the firewall can be welded on as a replacement or overlaid also but I would weld it in.
01-30-2009, 08:48 PM | #12 |
mbgmike: PM sent on that firewall
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. |
01-30-2009, 08:51 PM | #13 |
I do have A/C but I do not have a heater being that I live in Florida I did not feel like I needed. Here is a pict of how we ran the A/C lines..
01-30-2009, 08:53 PM | #14 |
A/C lines
01-30-2009, 09:00 PM | #15 |
Heres mine.Im using a heater blower off a forklift for heat.I ran my hoses the same way Big al did on his truck.
77 swb starting all over again. |
01-30-2009, 10:50 PM | #16 |
Big Al what A/C setup did you go with?
And I like how clean the firewall still looks! Good Job!
01-30-2009, 11:34 PM | #17 | |
I went with classic auto air...
01-31-2009, 01:24 AM | #18 |
Junior Member
My 72 project firewall!
01-31-2009, 04:09 AM | #19 |
Where are you guys running the wires from or through?
If it ain't a chevy,I don't want it |
01-31-2009, 11:04 AM | #20 | |
no, not at all....on most after market kits, they have both heater and a/c controls.... |
01-31-2009, 11:25 AM | #21 |
In my truck the wires are still in the stock location on the firewall, however they were all extended and ran behind the lh side fender all the way to the bottom of the radiator support.
02-17-2009, 02:53 AM | #22 |
69
02-17-2009, 08:49 AM | #23 |
I used an aftermarket wiring harness. The light harness comes out just behind the inner fender. The engine harness comes out just behind and below the top of the engine. It noticeable, but not obvious.
03-07-2009, 11:18 PM | #24 |
Im interested in this as well. Can you get just an aftermarket heating system? I dont really want A/C.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
03-07-2009, 11:31 PM | #25 |
Seņor Member
Pics of mine done a few years ago. MC/booster, fuse panel, etc., are under the dash. The last pic is of my heater.
