when installing a disc brake conversion kit on my '70, is it good to use a stock disc brake proportioning valve from a 71-72?
I am a Referee of life.
Re: proportioning valve
You can use the stock 71-72 prop valve or an adjustable.You also need to change the Master Cylinder to a disc/drum one since the fluid demands of the disc setup is different from the drum/drum.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
also need to change to the proper size brake line
