![]() Join Date: Jan 2008
T350 or 400, opinions please
Hi all, building my wifes 60 sb I have decided to go with a 1968 292 as I was able to pick one up for a song and a dance. I am a manual fan myself but figured I would go automatic for the wife. I orig was thinking with the fuel costs the 700r would be the way to go but after thinking about it I decided a T350 would do just fine for around town cruising.
Anyhow question is, I have a quality guy here that does nothing but 350's with stall built well I am looking at 450$.. On another note I can pick up a 400 from a guy that has fallen on hard times and has been selling off his project, 400 was built to sit behind a big block and has zero miles. He has offered it to me for 400$ with TQ.. (the stall is good for my cam) Again I am not an automatic guy so I was looking for some input as to what I should do, the kick downs I guess are diff? What else am I in for other than the normal coolant lines ect, anything I should be looking at? Just trying to pick some brains on the topic. The real only reason I am looking at the 400 is when the wife loses interest ![]() Thanks Skez |
Re: T350 or 400, opinions please
I've heard that the 400's are the beefier of the two. But I'm kind of like you, I don't exactly know the real differences between the two. Heres some more food for thought, most 3/4 ton trucks that had automatics ran the 400 i do believe.
Ya, I know the gear ratios are diff, and the rear mount is a further back.. I think they are like a half inch longer and they kick down different, more common in towing/hauling dept.. just heavier duty all around, but other than that I dont know.. Thus figured someone here probably could give some insight on any experience they have had with them good/bad etc..
![]() Join Date: Sep 2006
Lets just say the TH400 is going to take too much HP to turn with the 292. Gas Mileage will suck.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
th 400 uses something like 23more hp I once heard. And my heavy duty 77 3/4 has a turbo 350, factory. I'd only run a th 400 if I had a big block.
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing. |
I would look for a 200R or 700R.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
