Old 01-29-2009, 08:06 PM   #1
otsenre
otsenre's Avatar
72 GMC front clip
I have heard that the 72 GMC front clip is the same as the 67-68 chevys, Is this correct? Other than the grill
otsenre is offline   Reply With Quote
Old 01-29-2009, 08:09 PM   #2
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: 72 GMC front clip
I think the fenders are the same on 68-72 GMC's as they are on 68 Chevy.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 01-29-2009, 08:20 PM   #3
jaros44sr
jaros44sr's Avatar
And you have the double headlite buckets spot welded to the core support
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-29-2009, 08:26 PM   #4
otsenre
otsenre's Avatar
Thats right, I forgot about the core support. By the way , I just shipped the harness via Fed ex, Let me know when you recieve
Old 01-29-2009, 08:34 PM   #5
jaros44sr
jaros44sr's Avatar
Thank you
SAFETY FIRST
AS usual, off topic
Jim
Old 01-29-2009, 09:09 PM   #6
68-72 GMC fenders are the same as 68 Chevy,that`s all.
Old 01-29-2009, 09:10 PM   #7
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
67 GMC's and Chevy's had the same fenders. 68-72 GMC's all used the same fender as 68 Chevy's. Only difference between the 67 and the 68 fenders were the addition of the side marker lights in 68.
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 01-29-2009, 09:11 PM   #8
dieselarmy13
Tim beat me to it.
Old 01-29-2009, 11:20 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you can swap out the entire front clip GMC to chevy though.
Old 01-29-2009, 11:31 PM   #10
True,and that would be "different".Especially the hood.
Old 01-30-2009, 11:56 AM   #11
otsenre
otsenre's Avatar
So the hood is different than the 67-68 chevy? I can answer my own question here, I went and saw this 72 GMC, I saw where the hood is same as 69-72 chevy, Now if fenders are the same as 67-68, I can use the 67-68 hood on this 72 GMC front clip. Right? This 72 is in nice shape, I bought it for the bed, has a nice grill, AC cab, solid cab supports, nice doors etc. You will see it in parts here as soon as I get it home
Old 01-30-2009, 04:21 PM   #12
otsenre
otsenre's Avatar
ttt
Old 01-30-2009, 05:40 PM   #13
Yeah,let me break it down....
First of all,`67 Chevy & GMC grilles are the same,except Chevy has letters.`68 is the same except for the different letters.
Only Chevy fenders changed in`69.
All hoods changed to the same hood on Chevy/GMC in`69,except GMC has holes for letters.
All GMC grilles,67-72 can be interchanged on GMCs.
In`69 when the hood changed GMCs recieved a surround just like chevys did,but...it is three seperate pieces not part of the grille:2 fender brows fastened to the fenders and a top piece fastened to the grille.
This was necessary because when the hood got steeper in`69 it got shorter and the surround fills the gap.
So...if you use a 67/68 hood you can run any GMC grille w/o the surround.There`s the narrow trim that`68s came with if you want to use that.
You can use a 69/72 hood with any grille,but you`ll need the 69/72 surround pieces.
Old 01-30-2009, 07:02 PM   #14
otsenre
otsenre's Avatar
Old 01-30-2009, 07:46 PM   #15
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I (for one) would like to see the pictures that illustrate these differences. Since I'm into Chevies, I don't have the detailed info on GMC's. But, I have owned Jimmies, but not the '67-72's.
Member Nr. 2770
Old 01-30-2009, 10:15 PM   #16
Longhorn Man
I find it disturbing that you have that photo on your computer.
I find it even more disturbing that i am most likely gonna come back later and right click and save it.
Old 01-30-2009, 11:50 PM   #17
jaros44sr
jaros44sr's Avatar
Now that is just plain funny, that being said, will also rite click(tired of those little people)
If you buy the '67, '68 core support you can make any of the above combinations work
SAFETY FIRST
AS usual, off topic
Jim
Old 01-30-2009, 11:59 PM   #18
67_C-30
I have a radical idea!
67_C-30's Avatar
Here you go LoRay,
First pic: 68-72 GMC and 68 Chevy fender. This is a '69 fender pictured, but as you can see even with the brow trim removed it still smooth on the front.
Second pic: 69-72 Chevy ONLY fender. Notice the indention on the front for the aluminum grills on the Chevys.
Third pic: 67 ONLY GMC and Chevy. Note there is no side marker light.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 01-31-2009, 12:02 AM   #19
67_C-30
67_C-30's Avatar
Jaros44, although your trim combo works and look good, it isn't factory correct. I'm sure you know this, I am just clarifying for the others that the 69 - 72 GMC's that came with that upper brow you are using did not have the indention like you fenders do. Your fender is a '69 - '72 Chevy fender.
That is a very unique look you have though. I like it!
My trucks
Old 01-31-2009, 12:13 AM   #20
jaros44sr
jaros44sr's Avatar
That is why I posted both, but I didn't like it and went full '68. My point was that anything can be created, and thanks for keeping that clear
SAFETY FIRST
AS usual, off topic
Jim
Old 01-31-2009, 12:25 AM   #21
67_C-30
67_C-30's Avatar
Cool. I was hoping you wouldn't think I was trying to correct you or anything, because I knew you knew the difference in them.
You're exactly right about creating any combination. Rokcrln's Low Buck truck is a the perfect example of a Duke's mixture in regards to these trucks. He's got just about every variation covered from 67 to 72 on it!
My trucks
Old 01-31-2009, 09:36 AM   #22
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I appreciate the photos. My (damaged) brain just wasn't letting me visualize everything that it needed to assemble it. Thanks.
As for the picture, I refuse to take credit for it. It was on another post a few weeks ago and I did a right-click to capture it, too. Go for it.
Member Nr. 2770
Old 01-31-2009, 10:16 AM   #23
jaros44sr
jaros44sr's Avatar
If you try to put anything but a factory 2 core radiator in the '67,'68 core support you will have problems with the flange underneath the rad. You can bend it down or cut it off. Also the lower rad. mounts need to be clearanced for 4 core...Simply stuff
Changed it again, got some OEM '68 fenders off of the classified, waiting to paint, then I'll hang 'em
Support the Classifieds, great resource for used parts, and you'll meet some very interesting people
SAFETY FIRST
AS usual, off topic
Jim
Old 01-31-2009, 11:33 AM   #24
67_C-30
67_C-30's Avatar
Hmmm, I did not know that. I am going to have to run a big 4 row in my '67 C-30 to keep the diesel cool. Thanks for the heads up! I guess I can plan on modifying yet another part of my truck! I don't think a 2 row is gonna work with big green beast!
My trucks
Old 01-31-2009, 11:42 AM   #25
jaros44sr
jaros44sr's Avatar
Sweet, what is that thing?
SAFETY FIRST
AS usual, off topic
Jim
