Active Member
![]() Join Date: Dec 2003
Radiator Support Rubber Mounts
I need two radiator support rubber mounts. These are the rubber inserts that go in the bottom of the radiator support and the top radiator support brackets.
I need the original rubber inserts. I have new ones but they are a little taller than the originals and the rubber is a little stiffer, and don't fit just right. I need the inserts for a 4 row radiator. Any help would be appreciated. |
Re: Radiator Support Rubber Mounts
If you are talking about the rubber pad that mounts against the radiator for a 4 core the GM part number is 15502586 list price was $6.44 ea. 1st. of jan. they are still available.
