Old 01-30-2009, 01:15 AM   #1
larryd
larryd's Avatar
72 Blazer AC mounting - 350 small block
Are all ac compressors mounted on the passenger side of the engine?
larryd is offline   Reply With Quote
Old 01-30-2009, 01:49 AM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: 72 Blazer AC mounting - 350 small block
As far as i know, all the 67-72 V8's had them on the passenger side.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 01-30-2009, 08:37 AM   #3
RLONG
RLONG's Avatar
All that i have seen have been on pasenger side could be other side if a add on air i guess. As for as chevy, GMC trucks and blazers right side always.
RLONG is offline   Reply With Quote
Old 01-30-2009, 10:56 AM   #4
larryd
larryd's Avatar
Thanks all for your info. I am restoring a Blazer and the ac compressor was in
the back of bed with no brackets. I do not remember when I tore it down what side the alternator was on and cannot find my pics of this. When putting this back together the alternator bracket mounts on the passenger side. This may not have been the original engine. I will need to scrounge up some ac and alt brackets.
Thanks again.
Old 01-30-2009, 11:11 AM   #5
Livrat
Member #1049
Livrat's Avatar
Heres is a couple of pictures to help you out...(One AC bracket is not pictured)
If you have a hard time scrounging up the parts I have all the brackets and pulleys needed...
Livrat is offline   Reply With Quote
Old 01-30-2009, 11:22 AM   #6
jaros44sr
jaros44sr's Avatar
Wow, I'm impressed. If that is your work, I applaud you, looks like the showroom example...
One question, how deep did you dent the firewall for the HEI?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-30-2009, 11:40 AM   #7
Livrat
Member #1049
Livrat's Avatar
Thanks for the comment!
I am not sure how deep the denting is.. Never did measure it.
Instead of moving the assembly forward the PO did "ball peen hammer" body work on the firewall to use an HEI with the Big block that "was" in the Burb.. he also did a little to the passenger side for valve cover clearance. At first I was going to cut it out and fix it, but decided to just smooth it up a bit and leave it be..
Old 01-30-2009, 08:37 PM   #8
BLUE THUNDER
BLUE THUNDER's Avatar
here's a pic of mine, hope it helps. Mario
BLUE THUNDER is offline   Reply With Quote
Old 01-30-2009, 11:52 PM   #9
larryd
larryd's Avatar
Thanks for everyone's help. If these pictures post ok you can see what i am working with. I found some drivers side alternator brackets but will need to locate the passenger side ac brackets.
Old 01-31-2009, 01:13 PM   #10
Livrat
Member #1049
Livrat's Avatar
Larry, If your looking to go back to factory stock, non of what you have pictured will work.. (other than the alternator and fan).
If you have found the drivers side alternator brackets you would still need the two crankshaft pulleys.. a short water pump and matching pulleys, the power steering pump,hoses,brackets and pulley, And all of the AC brackets.
I can help you with everything you need.
Old 01-31-2009, 09:06 PM   #11
larryd
larryd's Avatar
I just bought the water pump and told the parts store what year etc I had and the new water pump matched the take off one. I think I should keep it stock. I plan on keeping the body/interior as stock as possible. I may need to take you up on the parts.
Old 02-15-2009, 12:40 PM   #12
larryd
larryd's Avatar
Unhappy Re: 72 Blazer AC mounting - 350 small block
Looks like I will be mounting the ac compressor on the drivers side after all. I never realized that the heads were drilled different with 3 holes for the ac bracket and one one for the alternator bracket. I would have to change the
heads and I think that is not worth the cost or time.
Old 02-15-2009, 12:57 PM   #13
Livrat
Member #1049
Livrat's Avatar
Larry, No need to change heads to go back to the stock parts, The factory passenger side AC brackets do not use any of the holes on the heads for mounting.
Old 02-15-2009, 01:26 PM   #14
larryd
larryd's Avatar
Thanks, I will proceed as planned. My compressor has the brackets that bolt to each end still on it. I have been gone lately and need to get back to work on this.
