Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 01-30-2009, 11:59 AM   #1
BarryB
BarryB's Avatar
I put blazer buckets in today, with a couple of pics
Here is for all the guys that are curious of this swap. First i took out the bench seat by removing the 4-15mm nuts. and removed the bench. I then vacuumed the heck out of the carpet, got some lunch out there also, some left over petrified Mickey Ds french fries.EWW! On with the buckets. I put outside tracks fit perfectly over the existing studs from the bench. I marked the the inside track holes and removed the bucket so I could take a 3/8" drill bit and drill the 2 needed holes for the inside track. You'll need to do this on both sides obviously. Go get 4 3/8" 2-2 1/2" long bolts, nuts and washers. For the bottom/underneath get the biggest fender washer you can get. This helps from the bolt pulling threw the floor in case you are ever in an accident.
Put the seats back in and tighten everything down and away you go. I really like them in my truck. The set a bit higher and alot more comfortable, and it looks so much better.
All time involved, was roughly a hour.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 02-05-2009, 08:57 PM   #2
BarryB
BarryB's Avatar
Re: I put blazer buckets in today, with a couple of pics
Man, I figured I would have had a couple comments by now. oh well. J/K I've been driving it now for about a week with the buckets. I keep telling myself why did I wait so long to do that. much better.
Two rules in life.
Old 02-05-2009, 11:48 PM   #3
Arad68
Trucks N Tranzams
Arad68's Avatar
Looks good!! I am glad that you like them!!!
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 02-06-2009, 09:05 PM   #4
Jonce
Jonce's Avatar
I did the same thing with my truck. Did you have to make brackets or did you just drill new holes? I'm going to make some brackets for mine this Spring.
__________________________________
1971 GMC Stepside
350HO Deluxe 330hp, TH350 w/Gear Vendors, 3.73 Eaton posi, Fitech EFI, Boyd's Welding Tank, Ridler wheels, ECE 4/6" drop, front/rear sway bar
Jonce is offline   Reply With Quote
Old 02-07-2009, 06:16 PM   #5
BarryB
BarryB's Avatar
I didn't need to make any brackets. Just had to drill the floor and bolt them down.
I like that console,Looks good in there. Thats out of a Monte carlo correct? I had one a while back but sold it on ebay.
Two rules in life.
Old 02-07-2009, 11:13 PM   #6
Arad68
Trucks N Tranzams
Arad68's Avatar
It looks like a Blazer or Envoy console to me.
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
Old 02-08-2009, 02:49 PM   #7
BarryB
BarryB's Avatar
You know now that I look at it again, your probably right. The monte Carlo is Very similar but it has a bigger panel in between the shifter and storage compartment.
Two rules in life.
Old 02-08-2009, 03:23 PM   #8
protrash64
Resistance is Futile
protrash64's Avatar
Your buckets look good in there......like they shoulda been there the whole time!!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
