New Member
Tightening Tie Rod ends
I had previously loosened up my inner tie rod ends, and now I cant seem to tighten them back up. Once the bolt gets on the threads, the tie rod keeps spinning, preventing it from being tightened. Am I doing something wrong, they are really loose, as in a lot of play, they loosened up fine, maybe its me? Any help would be appreciated.
#2 | |
Re: Tightening Tie Rod ends
You have to force the taper to hold the tie rod shaft. Either pry against the rod itself or squeeze it with some large slip-joint type pliers to prevent the spinning. You might also try cleaning up the threads of the stud and the nut so that they spin together easier, this will allow the nut to tighten rather than spinning the stud.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#3 | |
accepting donations
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett |
New Member
Coo, I'll try that. I can't get back on it until Monday, but I'll give it a shot.
