LET'S GO...MOUNTAINEERS
New valve covers...
What do you think? I got a set of Holley covers to match the carb. Plus the Edelbrocks were too tall. These things were oxidized bad, but a friend of mine at work did a hell of a job.
72 SWB/Step |
Old member
Re: New valve covers...
They look cool, but don't you think they would leak less with the hold downs and gorments in place!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Sierra Grande Club
Will these clear the stock alternator on the drivers side? Is that what was wrong with your taller ones?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
![]() Join Date: Jan 2009
what kind of header do you have?The lettering is to small to read on the tag in the picture.
'72 chevy k20 '06 H-D Springer softail http://www.bluemooncruisers.com/ http://www.enginecycle.com/ ~Eric ![]() |
Alternator is on passenger side. The Edelbrocks worked, just didn't like the height.
72 SWB/Step |
Doug Thorleys
72 SWB/Step |
#7 | |
Sierra Grande Club
I'm just trying to find my own answer to what will/wont work on stock alternator setups. No high jack intended. ![]() s/t
