01-31-2009, 11:51 AM | #1 |
is 100 psi good for a a.o.l. setup
Looking at a kit for a 78 blazer ,mine is flipped rear and just the 2 main leafs .The kit says not to inflate bags over 100 psi,do you think this is good enough for what I,m doing or go with a better bag
01-31-2009, 11:59 PM | #2 |
Happy to be here
Re: is 100 psi good for a a.o.l. setup
What type of bag is it? I'm running an AOL on my 77 with 2 leaves and a sleeved bag. At ride height, I'm usually running 52-56 psi. With the Blazer having more weight on the rear you might require a bit more.
02-01-2009, 11:14 AM | #3 |
Its a kit from pacbrake $250 I figure I could make something work with the brackets,not really what I want for brackets but the price is right
02-01-2009, 03:21 PM | #4 |
Happy to be here
Don't compromise the integreity of your suspension to "make it work". Just like your brakes, suspension is not a place to cut corners. Do it right now, or regret it for a long time later....
02-01-2009, 03:59 PM | #5 |
I,m not cutting corners just for that price I get the bags and brackets and fittings,just the lower brackets are wrong for me but they are $20 for lower brackets.I will send you web page and you can see the kit
02-02-2009, 07:47 PM | #6 |
I,m trying to do your setup nutrux,let me know if this is a good start
02-02-2009, 08:36 PM | #7 |
Happy to be here
Those look more like helper bags. Do some research and see if they aren't designed to assist in load capacity. Did you price the ART set up?
02-03-2009, 11:08 AM | #8 |
No i didn,t price art out yet,just that this company is here in town
02-03-2009, 11:12 AM | #9 |
What is the difference between helper setup and other,the bag.I can get firestone bags here too but what bag to get ,2600 ,s or?
02-05-2009, 11:32 AM | #10 |
what firestone bags to run for aol on 78 blazer
02-05-2009, 12:37 PM | #11 |
Happy to be here
I have been sick so I haven't spent much time researching on the forum. Let me see if I can get you an answer.
02-05-2009, 01:11 PM | #12 |
Are you wanting to do an AOL set-up just like Kens 77? A sleeve type bag works well on AOL set-up's where some of the leaf pack has been removed; dbl convoluted bags should be avoided w/this set-up as the ride suffers when used in a 1:1 configuration.
If the airbag is truely just a 'helper' bag, you can get away w/a dbl convoluted style since it won't have much air pressure when not in use.
02-05-2009, 07:43 PM | #13 |
the pic I showed is a heavy duty helper from pacbrake.I,m trying to do aol with 2 main leaves remaining.I know the blazer is a little heavy.Also with all but the 2 main leaves remaining will it sit much lower than with all the leaves, just a guess so I can compinsate for adding a lowering block so it will sit in the notched frame when aired out,hope that is all,thanks for your time
