Old 01-31-2009, 01:17 PM   #1
Nitebytes
Nitebytes's Avatar
Need Help Please - Fuse Blowing
Hi all.
I've just replaced my starter motor (it needed a refurb and turned out to be to totally buggered), and now whenever I crank the engine the 10a fuse for the fuel pump blows.
This wasn't a problem prior to the starter swap out. Any ideas / hints / tips ?
This is not my signature.
My signature is an almost illegible squiggle.
My Blog | My DeviantArt | MySpace | Facebook
1974 Chevrolet C30
Nitebytes is offline   Reply With Quote
Old 02-01-2009, 12:42 AM   #2
Square84
I don't think these pills work
Square84's Avatar
Re: Need Help Please - Fuse Blowing
sorry to state the obvious but you have got a short. you pinched or broke a wire while you were changing the starter go over your wiring around the starter and see if a wire is bare and touching metal. sorry couldn't be of more help.
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 02-01-2009, 01:16 AM   #3
lvschevytrucks
Unfinished Project Club
lvschevytrucks's Avatar
lvschevytrucks is offline   Reply With Quote
Old 02-01-2009, 01:43 AM   #4
Longhorn321
Size Matters
Longhorn321's Avatar
Does the fuse blow instantly? Does the truck run at all before the fuse blows?
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 02-01-2009, 05:03 AM   #5
Nitebytes
Nitebytes's Avatar
That's what I thought, but I'll be buggered if I can find it, hence I was asking for help. I'll grab the meter and check again.
Instantly.
1974 Chevrolet C30
Old 02-02-2009, 12:07 PM   #6
Longhorn321
Size Matters
OK...Let's start with what kind of vehicle you are working on. Your sig. says '74 C30 but that would have a mechanical fuel pump sooo... You very well may have a short circuit to ground and I would def. check in the area you were working but it could also be coincidence. If you dont find anything near where you were working, try unplugging the fuel pump (if you can get to it) and then see if the fuse blows.
...WOOOO HOOOO!!!!
