67-72 Addicted
Quick control arm question
Is it the upper or lower control arms from a 3/4 ton the same as 1/2 ton? Thanks
Fabricate till you "puke"
Re: Quick control arm question
the uppers are the same(just swap the ball joints). The lowers have a different sized hole for the ball joint ,1/2 vs 3/4 ton. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
