01-31-2009, 03:56 PM | #1 |
front end swap question
1st do i need these?or do my 79 bolt to my 64 here?
2nd what is the easiest way to clean all this?gonna us rust bullet on it afterwards. should i use the 79 coil springs or what? i want to lower it anyways later on. thanks all. |
01-31-2009, 05:47 PM | #2 |
Re: front end swap question
as far as cleaning , what i've done in the past is scrape the heavy stuff off , get some gunk engine degreaser and hit with a power washer . if you dont have a power washer hit the local car wash with a pocket full of quarters.
when i've done this i still usually have a very light coating of dirt that can be knocked off with steel wool or a wire brush . then use laquer thinner or some other solvent to wipe it down and get the residue off .
hey.....smell my finger 64 nova wagon , 63 nova convertible |
01-31-2009, 06:18 PM | #3 |
thanks jbon64
01-31-2009, 06:25 PM | #4 |
Registerd User
Check out the suspention forum. I bet youll find everything you need to know.
01-31-2009, 06:55 PM | #5 |
I'm not sure what you are asking in the first pic???
CHEVY ONLY |
01-31-2009, 07:13 PM | #6 |
i was wondering if i had to remove that bracket the piece that the upper a arm shaft bolts to. or does the shaft bolt right up to those 2 bolts on my 64.
01-31-2009, 07:31 PM | #7 |
64-66 CHEVY JUNKIE
No you dont need to remove that bracket, the upper and lower will hook-up to..... the front x-member......Heres a few pics hope.......it help ......CHRIS...
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E Do It In A Chevrolet |
01-31-2009, 07:31 PM | #8 |
64-66 CHEVY JUNKIE
[IMG][/IMG]
01-31-2009, 07:34 PM | #9 |
64-66 CHEVY JUNKIE
These are 72's and they mount with..... no problem.......
01-31-2009, 07:34 PM | #10 |
64-66 CHEVY JUNKIE
[IMG][/IMG]
01-31-2009, 07:40 PM | #11 |
thanks what paint or coating did you use? spray or roll on?
01-31-2009, 07:51 PM | #12 |
64-66 CHEVY JUNKIE
I cleaned, scraped the heavy stuff then used easy-off ...... . Yeah Oven cleaner!! let set and sos pad or wire brush and rence off with water..... Prime.... And paint with Rustolem marine coatings...... ITs not por-15 but it will hold......[IMG][/IMG]
01-31-2009, 08:19 PM | #13 |
The 79 control arms will bolt up to your crossmember.. I used 75 control arms. Here are just about the only pictures I have for now. I have energy suspension bushings and new ball joints to put in.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
01-31-2009, 08:20 PM | #14 |
looks good gulfcoast66
01-31-2009, 09:21 PM | #15 |
when buying lowering coil springs do i buy 66 or 79 models? does it matter?
01-31-2009, 09:54 PM | #16 |
Hey Y'all!!
Doesn't matter for the front. If your rear is coil also, you will need rears for a 60-72 coil spring application.
Just hopin' I live long enough to finish something!!! |
01-31-2009, 11:25 PM | #17 |
I used the springs from the 75 with drop spindles. I think the later model springs are about an inch shorter then the 64. I am not sure about this though.
I remember this. After 4 years of driving is what the last pictures were of.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 01-31-2009 at 11:31 PM. |
