Old 01-31-2009, 04:09 PM   #1
au03z71
au03z71's Avatar
Engine Paint
Where can I find the hugger orange paint for my engine? And, do I need a basecoat or primer?
au03z71 is offline   Reply With Quote
Old 01-31-2009, 04:23 PM   #2
adpostel
New Member
Re: Engine Paint
If you can't find it in the local auto parts stores, which you should be able to, but if you can't, I ordered all my paint from JEG's and they had every thing I needed. I painted my engine Fire Engine Red, and it was hard to find in the locals in an engine temp resistant paint. JEG's had it, If I'm not mistaken, I think VHT makes it, but I could be wrong. and I didn't primer mine, just wire brushed really well, and then wipe clean with MKT or Mineral Spirits.
1968 C10 LWB Project 454/400
http://www.cardomain.com/ride/2417713
adpostel is offline   Reply With Quote
Old 01-31-2009, 04:25 PM   #3
adpostel
New Member
Re: Engine Paint
Better yet, here ya go:
http://www.jegs.com/i//322/SP123/10002/-1
Old 01-31-2009, 05:06 PM   #4
au03z71
au03z71's Avatar
Re: Engine Paint
Very nice... and cheaper than I'd expected. Can I paint the headers with this stuff also?
Old 01-31-2009, 05:09 PM   #5
cdowns
cdowns's Avatar
Re: Engine Paint
it's not for headers
Old 01-31-2009, 05:40 PM   #6
au03z71
au03z71's Avatar
Re: Engine Paint
What can I use for headers?
Old 01-31-2009, 05:54 PM   #7
OhioDan
OhioDan's Avatar
Thumbs up Re: Engine Paint
Why not paint engine same as your truck? Paint won't burn till about 300+ degrees. If yer engine gets that hot, you won't be worrying about the paint burning.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 01-31-2009, 07:48 PM   #8
john02fxdl
Re: Engine Paint
No primer needed for engine paint. Paint several light coats instead of one heavy coat. Engine enamel is a bit thin and will run if you're not careful. Here's a secret, warm the spray can quite a bit(in front of a heater, not too close....boom) before you paint, will stick better with no runs. Hi-temp black or hi-temp cast iron gray for your headers, no primer on those either.
john02fxdl is offline   Reply With Quote
Old 01-31-2009, 11:25 PM   #9
elkynova
Re: Engine Paint
go to a schucks, checker or kragen and by VHT brand engine paint. It is good to about 550 degrees and comes in about every color. It is about 8 bucks a can...
elkynova is offline   Reply With Quote
Old 01-31-2009, 11:43 PM   #10
sierra4x4
sierra4x4's Avatar
Re: Engine Paint
The best engine paint I have used is Duplicolour Chevy red-orange. I have painted about 7 engine and they all look awsome. Don't use primer.
sierra4x4 is offline   Reply With Quote
Old 02-02-2009, 11:43 PM   #11
blazer72
Freedom isn't Free
blazer72's Avatar
Re: Engine Paint
oreilly's carries 1200 degree manifold paint - but nothing's perfect on exhaust - it just gets too hot - but it's the cheapest route. $8 a can.
blazer72 is offline   Reply With Quote
Old 02-03-2009, 11:41 AM   #12
leddzepp
Moderator
leddzepp's Avatar
Re: Engine Paint
POR 20 high temp manifold paint. Had it on my truck for years...does not come off, and can be brushed on.
leddzepp is offline   Reply With Quote
Old 02-03-2009, 12:07 PM   #13
big_al_71
big_al_71's Avatar
Re: Engine Paint
We used VHT paint bought from Autozone...Sanded it, wiped it clean and Three lite coats and it was done.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
