Old 01-31-2009, 07:15 PM   #1
ripdog28
ripdog28's Avatar
ECE trailing arms and Sway bars
As it says i have ECE square tube trailing arms and they have no holed for the sway bar to connect to. So some ideas i have are, Drill two holes all the way through and mount the pivots to them by 5in bolts and nuts, or cut two holes and weld some nuts flush. i am going for the first because it is so much easier and faster. my worry is the arms may lose some strength.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 02-01-2009, 12:43 AM   #2
ripdog28
ripdog28's Avatar
Re: ECE trailing arms and Sway bars
bump
69 c-10 BBC
Old 02-01-2009, 01:02 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
Here's my sway bar...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-01-2009, 01:05 AM   #4
Rollie396
someday it will be done!
Rollie396's Avatar
If you are worried about losing strength,I would drill the holes oversized and sleeve it with piece of tubing that has the appropriate I.D. for your bolt to fit through.That or do the same thing,but use a sleeve that you can tap to the proper thread size to allow you to bolt from the top.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 02-02-2009, 12:13 AM   #5
Rokcrln
Rokcrln's Avatar
I did this same thing a few months ago and I went with the second way you mentioned. Now what if you weld a piece of 1/4" flat stock to the side bottom of it and drill and mount you sway bar to that?
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 02-02-2009, 06:23 PM   #6
ripdog28
ripdog28's Avatar
Thank your for the ideas guys. still not sure what one i will go with.
69 c-10 BBC
