Old 01-31-2009, 10:41 PM   #1
gary2232
Brakes always On???
I have a 1972 1/2 ton 4x4. I replaced master cylinder about 5 weeks ago due to a soft pedal. Now I noticed a brake smell and a drag a few days ago? It looks like the front brakes are staying engaged some not locking but a drag sometimes harder than other times. Could this be a proportioning valve? Any advice?? Thanks
gary2232 is offline   Reply With Quote
Old 02-01-2009, 11:48 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Brakes always On???
There should have neen a paper in the box telling you about how to adjust the pushrod. You need to shorten the pushrod just a 'lilbit.
You sure it's the front, and not the rear brakes dragging? I've always had the rears drag in this scenerio
Old 02-01-2009, 01:16 PM   #3
gary2232
Thanks for the response. But I do not understand?? The push rod for the master cylinder? There was info to prime. Do I grind the rod to shorten? How much? 1/8" too much?? Sorry for posting in wrong forum thanks for moving..
Old 02-01-2009, 02:06 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
There's an adjustment under the dash.It's a threaded nut/rod.I didn't think to take a pic of mine when I had it on the bench but it would be handy since you can usually only do this by Braille.Basically you shorten the length of the rod by screwing it in then tightening the jsam nut.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-01-2009, 11:24 PM   #5
Longhorn Man
power brakes, or manual? The adjustment differs between the two.
Old 02-02-2009, 10:41 AM   #6
gary2232
Power Brakes Any setup info you have or advice will help Thanks Longhorn
Old 02-02-2009, 11:07 AM   #7
BluTrukker
BOHICA
BluTrukker's Avatar
Did you replace the pads/rotors/calipers at the same time? I replaced the pads and rotors on my little work beater a couple months ago and had the same issue. What I found was a little rust spot on the pins that the calipers slide on. It wasn't allowing the brakes to fully release and they would drag for a little while. Warped a brand new set of rotors before I figured it out.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig!
BluTrukker is offline   Reply With Quote
Old 02-02-2009, 11:14 AM   #8
gary2232
Did the rears last year and fronts checked ok. Thanks
Old 02-02-2009, 08:14 PM   #9
gary2232
OK found in book that 1/8" lash in pedal travel I have 1/2" Any short cuts to removing linkage? The bolt through pedal arm will not come out because of steering column. I was thinking of opening a bleed valve to allow pedal to go to floor to remove bolt??? Any ideas???
