Old 02-01-2009, 02:44 AM   #1
thunderkiss65
which brake master cylinder/booster to use
I'm underway in rebuilding a 65 c10 I picked up a while back and Im swapping the front end out with one from a box chevy and need to know which master cylinder and booster to use. Will the booster/master cylinder out of my 83 donor truck work or do I need to rob the setup off of my 71? Any help would be great. thanks guys.
thunderkiss65 is offline   Reply With Quote
Old 02-01-2009, 11:14 AM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: which brake master cylinder/booster to use
Either set-up will work. I dont know the particulars, but I believe the only issues are with the length of the pushrod, potentially. Most have been abe to overcome any issue with the rod by small corrections to its length thru welding or moving the mounting point. Some set-ups are completely bolt on with no issues.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
