Old 12-10-2002, 01:10 AM   #1
low 84
low 84's Avatar
Thumbs up i'm redoing EVERYTHING!
here is the list to redo the whole suspension, not set in stone yet.
Anti Sway Bars
http://www.sporttruckdirect.com/hellwigbars.html
front = $150
rear = $150
Front End Kit
http://www.performancesuspension.com/main.htm
Upper & Lower Ball Joints
Inner & Outer Tie Rod Ends
Idler Arm
Complete Upper & Lower Shaft Assemblies
Graphite Impregnated Polyurethane Bushings*
Upper & Lower Control Arm Bushings
Sway Bar Bushing Kit with Brackets
Polyurethane Tie Rod Boots
kit = $280
Front Breaks
http://www.stainlesssteelbrakes.com/...ize%20Truck%20(2WD)&year=1984
Slotted Rotors
Hi.po pads
kit = $305
Shocks
edlebrock ias shocks
4 = $280
Steering
dunno yet, looking for closer ratio box
Locally Purchased
F.M. wheel bearings
Paint (cleaning painting all front end parts)
Rear drums, shoes, and rebuild kit
other misc.
used control arms (bent my lower left one)
estimated = $250
TOTAL = $1415 + steering parts + shipping
i'll be doing this over a couple weeks this summer. the stance of the truck won't cahnge but it will sure as hell handle/ride different. 80 mph 's' curves
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 12-10-2002, 01:39 AM   #2
67_SS396
You said "Impregnated"!! !!!!
Sounds like a plan Ryan. With all that fancy work, I bet she'll corner like she's on rails! If you need help, just yell. I've done my fair share of suspension work.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 12-10-2002, 03:06 AM   #3
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
If you do your front end kit first Ryan let me know because that'son my list of things I need to learn/do an would love to help as well as practice in case I haven't one mine by then.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 12-10-2002, 03:28 AM   #4
low 84
low 84's Avatar
this is gonna be my big project this summer brandon. so if you haven't done yours yet we can 'practice' on mine
'05 1500 Crew Cab
RIP
Old 12-10-2002, 09:12 AM   #5
BigRed
Count me in too!
Yep, count me in too! I'm always wanting to learn more. Of course, that's not too hard for me since I don't know much to start with.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 12-10-2002, 09:57 AM   #6
Izzy
Trucker.
Izzy's Avatar
I'd seriously suggest the front end kit from P-S-T. I've heard very good things about thier products. Also they make a front disc brake updgrade kit you may want to look into.
Izzy is offline   Reply With Quote
Old 12-10-2002, 12:06 PM   #7
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
That is what I want to do also!! Those are nice lookin rotors!! Couldnt find any slotted when I was looking , just the cross drilled PowerStop/PowerSlot brand
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 12-10-2002, 01:56 PM   #8
Tom
driving is in my blood
Tom's Avatar
The front sway bar, I think you can forgo. A 1 1/4 bar from a 3/4-1ton should be just as good.
Front brakes are no good. You can get powerslot rotors [made out of brembo blanks] for $90 a piece plus your standerd $30 brake pads= a few bucks saved
Shocks- good choice, althogh pricey
front end kit- good choice
Just my opinon if it matters
Old 12-10-2002, 03:09 PM   #9
low 84
low 84's Avatar
tom - are those rotors crossdrilled? i posted about those and people said they crack and warp?
'05 1500 Crew Cab
RIP
Old 12-10-2002, 03:24 PM   #10
messed up c-10
RHCP afficianado
messed up c-10's Avatar
looks like a good list. You gonna add it to the 400 cost?
~Ryan~
89 S-10 Blazer with a 4.3L
96 Ford Crown Vic P71 4.6L V8. This car rocks.
Here are some links to some good music.
Jack Johnson
Donavon Frankenreiter
messed up c-10 is offline   Reply With Quote
Old 12-10-2002, 03:40 PM   #11
low 84
low 84's Avatar
actually i'm forgoing the new motor for now until i get this knocked out. my current one shouldbe good enough once i put the heads on for a while. the breaks are craping out on me and there is like 4 inches of play in the steering. so i need to redo all this before i try puting 500 hp in it
'05 1500 Crew Cab
RIP
Old 12-10-2002, 04:16 PM   #12
Tom
Tom's Avatar
Ryan-
they are slotted only rotors. You might be able to get cross drilled, but I dont know I never checked. Dont believe in them excpet on race cars
When I bought the slotted rotors for my 99 accord, the instructions said use metallic pads. BAD IDEA! from the first time I hit the brakes there was a huge grinding, metal on metal noise. I tried changing the pads back and forth, side to side, everything. Nothing worked. Finally went back and got the OEM ceramic pads and never looked back.
Old 12-10-2002, 04:20 PM   #13
PHOENIX
Then he totaled the car try to be a race car driver!
EDIT:
Maybe you'd still have that Honda if the brakes were cross drilled. j/k
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 12-10-2002, 05:07 PM   #14
low 84
low 84's Avatar
Originally posted by Tom
Ryan-
ok thnx, i don't want crosse drilled ones, just slotted. can you link me to a site where they sell those ones you mentioned?
'05 1500 Crew Cab
RIP
Old 12-10-2002, 05:25 PM   #15
messed up c-10
RHCP afficianado
the play in the wheel is what makes driving fun. I need new brakes too and will probably add them to the top of my list.
~Ryan~
Jack Johnson
Old 12-10-2002, 05:48 PM   #16
Izzy
Trucker.
Izzy's Avatar
Ryan-
I've used Delco pads with great success on my sotted Powersots on my 98.
Old 12-10-2002, 07:04 PM   #17
LOHRTBT
LOHRTBT's Avatar
Power slot does not offer slotted rotors for our trucks...only cross drilled.
~Dave~
Old 12-10-2002, 07:50 PM   #18
Izzy
Trucker.
Izzy's Avatar
Doh.
Where'd you get yours and how much?
Old 12-11-2002, 12:56 PM   #19
Tom
Tom's Avatar
Unfortunatly I had to buy them at the local rice shop. Man did I feel low walking in there.
Eddie- stay out of this! "maybe you'd still have the honda if the brake were cross drilled" Gota addmit thats funny as sh*t!!
Old 12-11-2002, 01:22 PM   #20
LOHRTBT
LOHRTBT's Avatar
Izzy...they are from power slot or powerstop what ever you want to call them....they were like $119 if I remember correct, just give em a call.
~Dave~
