Old 02-01-2009, 02:01 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
x pipe ideas....
I saved this picture from someone on here, it look really clean to me but not sure if it would be too restrictive.
Now that I have my 2.5 in x-pipe and have looked at my situation this setup is more appealing.
It allows the pipes to use the factory recessed areas to tuck up the pipes so they wont be as visible.
I'm thinking 1.5 in pipes on a 383 aren't restrictive by any means so a few more bends won't be noticeable?
My x isn't quite like that in the picture, so I'll try to substitute 45's in place of the 90's.
What do you think?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 02-01-2009, 02:13 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: x pipe ideas....
My opinion is that the X should be more "in-line" than this photo shows, but this may be better for exhaust flow than a simple H pipe....or not. I agree it's neat and fits well, but what fits isn't always what works best.
Member Nr. 2770
Old 02-01-2009, 02:23 PM   #3
Chevymann1968
Chevymann1968's Avatar
I agree!!!! Exhaust should have as little restriction as possible!!!! My self personally the only 90 shold be at the header or the manifold!! If i remeber right 5 90s become a complete block!!!
1968 GMC
Rebuilding Stage
2001 Camaro SS SOLD
Chevymann1968 is offline   Reply With Quote
Old 02-01-2009, 04:10 PM   #4
Smitty
Smitty's Avatar
Mine was done by a local shop that does a lot of street rods etc. and was done pretty much as this one was. Although I don't think the area where they are siamesed are quite as restrictive. A little less severe of an arch. With the drop I can't get under the truck far enough right now to get pics. But before the pipe goes into the muffler I had flanges put on. This way if I ever need to drop the trans all I have to do is take them loose from the manifold and at the rear flange. Allowing me to drop it down without a lot of hassle.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is online now   Reply With Quote
Old 02-01-2009, 04:23 PM   #5
67_C-30
I have a radical idea!
67_C-30's Avatar
Yeah, I agree. The path to and from the "X" should be a smoother transistion. The "X' in that set-up was actually intended to be turned 90 degree from the way it now.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 02-01-2009, 08:50 PM   #6
Ryan Hubbard
I worked for Dr. Gas and did a lot of research in exhaust systems and he was the one that started the x-crossover and still is used exclusively in Nascar. That system pictured does not work well. I would use a system close to what is listed in Jegs or Summit catalogs. The size of the hole in the crossover is critical to its performance. Too small and it does not work and too big doesn't work either. Here is a picture of my Dr Gas 3" System. I was able to install it in the factory locations just fine.
Ryan Hubbard is offline   Reply With Quote
Old 02-01-2009, 09:34 PM   #7
Sport/Truck
Sierra Grande Club
I'm not crazy about that x in the picture. He's a picture of my setup.
After looking at it today I might be able to mount it there by using my 45* bends.
Here's a picture of what I've got.
Anyone else have pictures of it mounted in this location?
Old 02-01-2009, 10:05 PM   #8
theyammieguy
accepting donations
theyammieguy's Avatar
those spin techs look like they sound awesome.
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 02-01-2009, 10:08 PM   #9
LuckyHenriksen
LuckyHenriksen's Avatar
Ya those look like awesome mufflers. I agree on the X in the first picture to be restrictive, those are some sharp bends. It might even change the exhaust note?
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 02-01-2009, 10:14 PM   #10
Sport/Truck
Sierra Grande Club
Thanks, they are definitely beefy!
s/t
Here's a picture of the inside.
Old 02-01-2009, 11:14 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the X in the first post looks highly restrictive. Probably more so than just running straight pipes/mufflers.
