Old 02-01-2009, 03:11 PM   #1
rddaves54
rddaves54's Avatar
gear indicator adjustment
I have a 72 Chevy with a tilt steering wheel column. Automatic 350 transmission and I replaced the bottom grommet on the transmission shifter linkage yesterday thinking that would correct the shifter dial and make it line up on the steering column.
I can put it in park but when I take it out of park it goes to neutral for reverse and 2nd for first. Is there a linkage adjustment I am not aware of so I can make it line correctly?
rddaves54 is offline   Reply With Quote
Old 02-01-2009, 04:10 PM   #2
Sammy
Re: gear indicator adjustment
Not real sure but I think you will have to rotate the column to the left and this will also require you to readjust your neutral safety switch which is PIA. Someone may diff. I left mine be for that way for that reason.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
