Old 02-01-2009, 06:46 PM   #1
ksbeatty
ksbeatty's Avatar
Proportioning Valve and brake lines
Is the proportioning valve for drum brakes prior to 1971 all the same? Also I have a 1970 3/4 ton 4x4 with power brakes and does the brake lines from the valve down run inside or outside of the frame? If you have pictures that would be great.
1969 GMC 3/4 Ton 4x4
2" Lift, A/C, PS, PB
383 Stroker, 700R4, 205, 4.10 GM
Medium Bronze (Copper Poly)
no new nick name yet. She is to pretty to be the Beater.
http://67-72chevytrucks.com/vboard/s...d.php?t=241855
ksbeatty is offline   Reply With Quote
Old 02-01-2009, 07:02 PM   #2
El Jay
Gone to greener pastures
Re: Proportioning Valve and brake lines
Can't help you on the valve.
But the brake line to the rear brakes runs down the inside of the right frame rail.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 02-01-2009, 07:50 PM   #3
ksbeatty
ksbeatty's Avatar
Thanks for the info. I need to really know where the ones from the p-valve. I think one goes one the outside and one on the inside.
Old 02-01-2009, 08:02 PM   #4
El Jay
They drop down to the rear of the front cross member.
