Old 02-01-2009, 11:39 PM   #1
DZL1
One day.....
DZL1's Avatar
Hard brake pedal
Newbie here. I just picked up a 72 C-10, V-8, swb, 2wd, automatic tranny. The brakes are hard. Was wondering if anybody can give me some insight as to what the problem or problems might be? Thanks in advance.
DZL1.
DZL1 is offline   Reply With Quote
Old 02-01-2009, 11:47 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Hard brake pedal
Welcome to the site...
Can you give us a little more info. Do you have power brake booster or is it manual brakes? Also, what do you mean by "hard?" Is the pedal hard to depress or is it just plain hard to stop the truck.
68gmsee is offline   Reply With Quote
Old 02-01-2009, 11:50 PM   #3
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
First of all Welcome !!!Asuming they are power . First check the vac line to the booster and the elbow that goes in the booster you can check it by removing it and make sure air only goes through it one way . If this checks out I would say it's time for a new booster. Bob
I Have The Right To Remain Silent,But Lack The Ability
1972 Chevelle ... Mine
2006 Trailblazer... Hers
2002 Buick century ... Kids
2002 K1500 Z-71 EXT CAB ... Daily Driver
2005 Rockwood Roo ... For Camping
1974 Harley-Davidson XLH Sportster 84'' stroker
Bob 68327 is offline   Reply With Quote
Old 02-01-2009, 11:54 PM   #4
DZL1
One day.....
DZL1's Avatar
Thank you for the greeting. Unfortunately I'm not sure if power or manual. How can I tell? The brake pedal is hard to depress, therefore making it hard to stop. Thanks again.
DZL1.
Old 02-01-2009, 11:56 PM   #5
DZL1
One day.....
DZL1's Avatar
Thanks, I will try that tomorrow, assuming they are power.
DZL1.
Old 02-02-2009, 12:02 AM   #6
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
under the hood it will look like this if they are power pic.1 Non Power pic.2 Bob
Old 02-02-2009, 12:35 AM   #7
DZL1
One day.....
DZL1's Avatar
Great pics! Well that answers that question. I have power, and I will try your suggestion. Thanks.
DZL1.
Old 02-02-2009, 08:45 PM   #8
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
Glad to help out .
Old 02-03-2009, 12:14 PM   #9
DZL1
One day.....
DZL1's Avatar
Ok Bob, I removed the elbow from the booster and it has good vacuum. So by your assumption, i will need a new booster. Correct or could it be something else? Thanks.
DZL1.
Old 02-03-2009, 02:52 PM   #10
68gmsee
Active Member
68gmsee's Avatar
Here's some thing you can try: http://www.mpbrakes.com/technical-su...ng-drum-02.cfm
There's a possibility that the master cylinder is defective or brakes contaminated. Eliminate all of the easyily checked/observed mechanical things first. Power boosters are expensive unless you can find one in a junkyard.
Old 02-03-2009, 03:09 PM   #11
OrangeCrush1970
OrangeCrush1970's Avatar
Dont buy anything new until you:
1 Check your brake fluid level (1/4" below top)
2 inspect your brakes / pads / adjust your drums
3 inspect your brake lines for leaks and cracking
4 inspect your vacum line from the brake booster to your manifold for cracks / leaks.
5 bleed your brake system.
These are all things that you need to do b/f you go out buying new parts...plus it's the cheapest way to locate your issue.
I had this same problem last week. We bled the brakes...not the problem. I then changed my vacum line to the brake booster and applied gasket sealer where the check valve (elbow that you spoke of) inserts into the brake booster. I then adjusted my brakes (drums).
Problem solved. Hope this helps!
Rottenwood Garage
1970...71...72 C1500 aka Orange aka Sideshow Bob
540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600
2 Tons of Fun
OrangeCrush1970 is offline   Reply With Quote
Old 02-03-2009, 08:05 PM   #12
DZL1
One day.....
DZL1's Avatar
Thank you guys for taking the time to answer my question. Orange Crush, my fluid level is lower than what you suggest, will fill. Brake lines are not cracked. will inspect brake pads. Vacuum line is fine. Will check vacuum pressure.
68gmsee, thanks for the link. My 72 has disc front and drum rear. I'm assuming the suggestions on that link will work on disc. It stated drum front and rear.
Thanks again guys.
DZL1.
