Old 02-02-2009, 12:01 AM   #1
OrangeCrush1970
OrangeCrush1970's Avatar
TH350 hanging onto 2nd
The truck is shifting well from 1st to 2nd, but hanging onto 2nd before shifting into 3rd. Sometimes shifts right into 3rd, sometimes hangs in 2nd. Fluid levels are fine, shifter is fine...is my transmission taking a dump on me or could it be a vacuum leak or bad solenoid?
This just started today-
I'll add that the transmission was rebuilt about 30-40k miles ago
Rottenwood Garage
1970...71...72 C1500 aka Orange aka Sideshow Bob
540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600
2 Tons of Fun
OrangeCrush1970 is offline   Reply With Quote
Old 02-02-2009, 12:13 AM   #2
72BLUZ
72BLUZ's Avatar
Re: TH350 hanging onto 2nd
sounds like maybe the modulator valve, or maybe a hole in the vacuum line going to it.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 02-02-2009, 12:34 AM   #3
sandking
.....I am working on it.....
sandking's Avatar
I would say either something with the modulator or maybe some debris somwhere in the valve body. Might be a good idea to do a really good fluid flush.
View my build thread HERE
sandking is offline   Reply With Quote
Old 02-02-2009, 05:52 AM   #4
72freak
Rottenwood Garage Member
72freak's Avatar
That would be my guess?!?!?
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 02-02-2009, 05:44 PM   #5
OrangeCrush1970
Modulator valves are $13. I think i'll get some new hose and throw one on there...after doing a little gooogling i read some and it sounds spot on for a bad mod valve or vac leak.
Rottenwood Garage
2 Tons of Fun
Old 02-02-2009, 06:07 PM   #6
jay6891
Car Knocker
jay6891's Avatar
x2 vacuum line or modulater were my first guess.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 02-02-2009, 06:29 PM   #7
thelonerife
thelonerife's Avatar
Mine started doing that on my truck. At first I could get it into 3rd by giving it a little more gas but that eventually quit doing it though. I changed my modulator and checked my hoses and fluid first too. I had to get it rebuilt. The clutches were gone. The bad thing was I had two trucks at the time and both started this within two weeks of each other.
thelonerife is offline   Reply With Quote
Old 02-03-2009, 12:08 AM   #8
72BLUZ
72BLUZ's Avatar
when it rains it pours, or at least around my house it does!
Old 02-03-2009, 02:32 AM   #9
70clone
70clone's Avatar
if all else fails put some trans x in it the stuff in the silver and blue jug.Works everytime ive ever used it.
70clone is offline   Reply With Quote
Old 02-03-2009, 03:31 PM   #10
OrangeCrush1970
I just replaced the modulator and rubber on both ends of the vacuum tube. When I pulled the old modulator off, there was a little fluid inside. Not too much which makes me think that it just started going bad.
It's shifting good now, i'll keep an eye on it and see if there are anymore issues, but I think I have the problem solved. It was a very simple operation (w/ the help of David's lift, etc.) and I figured yall would like some pics. Yes, it is very wet...
Thanks for the help fellas
Rottenwood Garage
2 Tons of Fun
