Old 02-02-2009, 01:41 PM   #1
19gmc67
19gmc67's Avatar
Question brake booster ?????
how hard it to put a brake booster on a drum brake setup.to make power drums
19gmc67 is offline   Reply With Quote
Old 02-02-2009, 02:16 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: brake booster ?????
If you can find a donor truck, it's not difficult at all. Everything mounts up.
If you dont, then you just purchase the parts individually or scrounge salvage yard or local sellers.
68gmsee is offline   Reply With Quote
Old 02-02-2009, 03:20 PM   #3
19gmc67
19gmc67's Avatar
does it work with any booster that fits our truck
Old 02-02-2009, 03:50 PM   #4
68gmsee
Active Member
68gmsee's Avatar
I used a booster off (IIRC) a 70 truck on my 68 GMC. You have to use the mounting bracket and booster, brake push rod, proportioning valve. I used my original master cylinder on mine since it was new.
There may be other's that work on these trucks but not sure which ones. See if you can do a search to go over some of the archived threads.
Old 02-02-2009, 05:48 PM   #5
kcjones
I wish I was a cowboy
kcjones's Avatar
Yes, the search will help, be careful with 3/4 vs. 1/2 ton stuff, there are differences in brackets, push rod lengths, m/c's, and boosters. Robbing a 73+ bracket, booster, m/c, prop valve would be wisest, wouldn't it?
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
Old 02-02-2009, 07:10 PM   #6
hchad18
hchad18's Avatar
The 73+ MC and booster bracket works but requires a little bit of modification because it is a taller bracket. There is a thread about that somewhere. Also you shouldn't need to worry about the proportioning valve with drum/drum. These are some good links for brake set-ups. If you already have the master cylinder on the truck just add a booster with the bracket. Mikes bump and grind garage seems to have pretty decent pricing.
http://www.bumpandgrindgarage.com/
http://www.hot-rod.com.au/builder/brakes.html
http://www.mpbrakes.com/uploads/documents/optomize.pdf
hchad18 is offline   Reply With Quote
Old 02-03-2009, 10:37 AM   #7
gcburdic
Restoration Virgin!
gcburdic's Avatar
I have a picture of one I have for sale over in the parts forum...http://67-72chevytrucks.com/vboard/s...d.php?t=321457...see post #2....bracket, push rod, booster, master cylinder, and proportioning valve is all there....
it came off my 68 that had a drum/ drum setup....I converted to disks fronts....
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 02-04-2009, 12:13 AM   #8
GMCMAX
Active Member
GMCMAX's Avatar
How-to pics
http://67-72chevytrucks.com/vboard/s...d.php?t=221598
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 02-04-2009, 01:21 AM   #9
19gmc67
19gmc67's Avatar
thanks for the how to photos
Old 02-04-2009, 01:23 AM   #10
westofb
I really hate wet sanding!
westofb's Avatar
I did this to my buddies 69. Got a booster and all the peddle linkage from a 72 truck. Used the original master cylinder and proportioning valve that were on the 69. Only problems we had were: 1) bolting on the master cylinder, the nose of it was too low so we shimmed the bottom two bolts on the booster to level the mc; 2) the original brake lines had to be broken loose to allow them to swivel slightly as we moved the mc to it's new, farther forward, location (the lines had to also be bent slightly to make the move, taking care not to kink them); and 3) the brake switch had to be adjusted to get the brake light to function properly (this is a huge PITA, take out the instrument cluster to be able to "kind of" see what you are doing). He now has power brakes that work as good as my OEM power brakes work. I think it took about 2 hours to do the swap...about an hour to adjust the brake light switch...lol. Good luck!
westofb is offline   Reply With Quote
Old 02-04-2009, 01:37 AM   #11
westofb
westofb's Avatar
oh, I forgot that you need the vaccum hose from the donor as well. If you have an quadrajunk or edelbrock carb, hook this to the base of the carb like on the donor truck...also grab the fitting in the carb that the vaccum hose threads into, this will fit quad and edelbrock carbs...hope this helps you with your swap. I looked at the thread from gmcmax, nice pics....I now remember taking out the bolts holding the column to the dash to get the bolt out of the rod hooked to the peddle, maybe not necessary but make getting that bolt out, it is kind of tight quarters in there.
