Stock speedo cable bending radius
The stock speedo cable comes up inside the engine compartment and does a lazy bend thru the firewall into the speedo head. I want to run mine up the inside to keep the firewall clean. Has anyone done this with the stock cable? Don't want to do all the work to find I am binding it up because of too tight a radius. Thanks
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Re: Stock speedo cable bending radius
Bump. looks like I will just do the trial and error method.
Which way does the speedo cable turn?? Thanks
Looking at the speedo, the needle rotates clockwise so that is the way the cable rotates. The inner cable is very flexible so a tighter bend shouldn't hurt anything. It will put more stress on the back of the speedo housing so you may want to support it with a bracket.
#4 | |
Turned out to be a non-issue, thanks for all that replied. I got to quit over thinking some of this stuff....
Realize this is an old thread, but instead of starting a new one thought I piggy-back on this one. I purchased a new speedo cable for my 59 Apache last year and it has worked flawlessly, but recently I cleaned up my firewall and brought the cable in from down low causing a tighter bend as OrrieG noted. Well, now the speedo is wacked out and bouncing all over the place. If it's not the tight bend to blame what could I have done wrong? I've removed the ends and made sure they were clean/lubed a few times now and still no improvement. Appreciate any helpful advice!!
I don't know if this will help but I seem to remember my dad grinding off the end of the cable to stop the speedo from bouncing. Maybe your tighter radius is pushing on the speedo housing/gears? Try loosening the nut holding it to the speedo so it pulls out a little or disconnect it from the trans and spin it by hand or with a drill to see if it's free. I'm done.
