Old 05-09-2002, 10:57 PM   #1
Jesse 67 c-10
Jesse 67 c-10's Avatar
Post one piece driveshaft
I'm finnally getting close to finishing my 5 speed swap and I'm wanting to go to a one piece driveshaft, from the very best of my measurments I need a driveshaft 67" long from the end of the yokes. (longest dist) What have other people taken a one piece out of? I'd sure like to find one I don't have to cut, I have a bit of room to play because my slip yoke has quite a bit of travel, it could be maybe a 1/2" longer or 1" shorter and still work. Any ideas? or if I have to cut and weld I've heard on here about putting some oil inside the driveshaft to get a fluid balance. any insight on this? Thanks!
Jesse
Near Saskatoon, Saskatchewan, Canada. 67 c-10, Long fleet, Newly swapped front disks, 5 lug rear end, 327 v-8 with Vortech heads, edlbrock performer rpm air gap manifold, 1406 carb and comp XE 256 cam. Backed by a getrag 5 speed and 1 piece driveshaft. Finnally running, almost driving! www.geocities.com/chevy67jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
Old 05-09-2002, 11:08 PM   #2
69 longhorn
Post
Cut& balance is only about $70 in my area,IMO good money spent. From what I understand,you should run a 4" dia shaft when going to a 1 pc in the 5 1/2-6 ft range on lenght(it can stepdown on the ends). To set up & measure lenght,you need to slide the slip yolk all the way the trans,mark it,then pull it out 3/4"-1",then measure C to C on the caps.Good luck.......69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 05-10-2002, 06:57 AM   #3
Woody
Post
Jesse,
You might look at large GM cars for your drive shaft. I have one from a 86 Caprice Wagon that I'm going to have shortened for my SWB and 700r4. I don't know the exact length of it, but it is close to what you need.
Woody
'69 Custom-10 Deluxe
Short Fleetside,Factory 350cid/TH400,A/C,PS,PB,Carpet
Coming soon 700R4, 350 Crate Engine, Pwr Disks...
Woody is offline   Reply With Quote
Old 05-10-2002, 11:29 AM   #4
Fast68Chevy
Fast68Chevy's Avatar
Post
yeah look under full size rwd cars, lots of them are in the 60's" for lengths, i have a stash of shafts from cars and such, they are all right around that length
good luck
Randy- Lincoln, IL
randy@ccaonline.com 2177353230
*many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham
current fleet: -71 C-10 350/CH465/3.07- basketcase, #1
-90 Cavalier 2.2L sky blue, a driver
-84 Z28 5.0L/700R4/3.73 daily driver
-84 Firebird/SE 2.8L/T-5/3.73/engine bad, project #2
-82 purple Trans Am, project #3
*Paint is overrated*
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 05-11-2002, 11:00 PM   #5
Jesse 67 c-10
Post
I went to the local yard today and I actually found a driveshaft the exact length, 66 3/4" ! I'm still amazed at my luck! I put it in, rolled it down a hill with the motor running, popped it in gear, drove it around for the first time in almost a year, with no clutch control, or brakes! I still need the hyd clutch hose and brake lines. Wasn't very practical but it was fun, and loud! Finnaly!
Thanks for the help
Jesse
Old 05-11-2002, 11:33 PM   #6
Fast68Chevy
Post
are lucky then !
make sure isnt shoved too far up into the back of the tranny
Old 05-12-2002, 09:10 AM   #7
HvyChevy454
Slowly getting CRSS...
HvyChevy454's Avatar
Post
that vehicle did you end up pulling the axle out of?
Lutz, Fl
My Team Website
The Heavy Chevy Website
  • 72 Cheyenne 10 LWB GM 12-bolt 3.08 w/ Auburn Posi
    91 454 Edel Intake 850 cfm carb Comp Cam 268/.500 Hedman Headers Dual 3'' Exhaust
  • 71 Cheyenne 20 4x4 Fact. A/C PS PB Tilt Currently in the works...
    Put it to the floor...
-Nic
Lutz, Fl
My Team Website
    91 454 Edel Performer RPM Intake 750 cfm carb Comp Cam 268/.495 Hedman Headers Dual 3'' Exhaust
Speak Softly and Carry A Big Block...
There is No replacement for Displacement...
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
HvyChevy454 is offline   Reply With Quote
Old 05-14-2002, 12:49 PM   #8
Jesse 67 c-10
Post
The axle is off a 72 chev, I don't know what the shaft is off of and the tranny's from a 90 chev 1/2t. Thanks for the help!
Jesse
