Old 02-02-2009, 11:28 PM   #1
centralchevyman
bump stops
i have a 71 chevy.I was wonder what people on here did about bump stops that had air bags on there trucks. Is it somthing that is need in case something goes wrong with the air ride. If so what is the best kind to get and where to get them. pictures from anyone that did this would be great.
Thank you
Jon
centralchevyman is offline   Reply With Quote
Old 02-03-2009, 01:38 AM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: bump stops
Its a good idea to design your suspension with a bump stop or something to keep the suspension from hitting the ground if a bag pops
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 02-03-2009, 12:58 PM   #3
centralchevyman
Re: bump stops
The frame or suspension does not hit the ground when it is all the way down. Are ump stops still needed if so what kind should i use.
Old 02-03-2009, 03:46 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Re: bump stops
Do your front tires hit the inner fenders when aired-out? If so, I would set a bump stop just before they touch, that way you do not lose your steering. If you are using upper plates, you can replace one of the mounting bolts with a screw-in style bumpstop from Energy Suspension or the like. Trim or shim as necessary to set it where you like...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-04-2009, 12:44 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: bump stops
Take a close look at this pic. Hopefully you can see what was built here. The guys that set up my suspension built a riser to bolt in place of the bump stop. This allows the suspension to rest on the stop and the truck will still roll.
It's a very functional option to have.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-04-2009, 10:48 PM   #6
centralchevyman
Re: bump stops
That picture helped out alot. Thank You for picture and help. I was just wanting to see a good way to make them.
Old 02-05-2009, 11:04 PM   #7
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: bump stops
My Slam Specialties RE7 bags have built in bumpstops. And that is how I roll.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 02-06-2009, 09:50 AM   #8
Shane
Shane's Avatar
Re: bump stops
I've read that the built in bump-stops on the Slam Specialties aren't designed to support the entire weight of a vehicle.
Shane is offline   Reply With Quote
