02-03-2009, 02:00 PM | #1 |
1972 rear view mirror?
I have a 72' GMC, and I had it restored . It has a new windshield and I forgot to mark where the little metal piece glues to the windshield. Could someone please measure theirs and tell me the measurements.Does the metal piece go exactly in the center of the windshield horizontilly the same distance left to right and how far down from the top of the windshield seal does it go? Thank you. Dave
02-08-2009, 09:05 AM | #2 |
Re: 1972 rear view mirror?
Help.TTT.
02-08-2009, 09:34 AM | #3 |
Old member
I wish I knew. I would help you out but my 71 has the one mounted to the cab roof. Sorry, somebody will chime in.
02-08-2009, 09:40 AM | #4 |
Junior Member
I'll measure mine..
72 cheyenne super BB402 TH400 Air Tack Tilt Posi P/S P/B AM/FM 12.96 @ 101.82 mph 60ft 1.82 12.39 @111.33 With a 180 shot nos 69 Camaro RS http://s94.photobucket.com/albums/l117/fdelcoglin/ email fdelcoglin@hotmail.com |
02-08-2009, 10:07 AM | #5 |
Junior Member
Mine is in the center of the windshield, 2.5 inch down from windshield molding to top of metal piece glued to windshield. maby someone else will measure to be sure as they do fall off alot..
02-08-2009, 10:30 AM | #6 |
02-08-2009, 02:13 PM | #7 |
FWIW 72 was the only year the rear view mirror was mounted to the windshield. All other years were on the roof.
00' Z28 ("wifes" car) 92' Mustang w/sbc everything needs a little heart beat 87' GMC Sierra Classic Short Bed Fleet side almost stock 69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it |
02-09-2009, 05:24 PM | #8 |
Hey guys , I saw another truck and I measured it and it was 3 1/4 inches from the seal to the top of the metal piece. Could a couple more of you please measure yours and see what the measurements are? Thankyou.
02-09-2009, 05:45 PM | #9 |
I'll check tonight
02-09-2009, 07:51 PM | #10 |
I am a Referee of life.
I doubt you will find an original measurement.The glue holding them on tends to let loose and most people just glue them back where it's comfortable for them.They may raise it a bit to get the mirror higher out of their line of vision or lower it so they can set it better depending on the usual drivers height.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
02-09-2009, 08:22 PM | #11 |
I have mine mounted 3 1/2 inches from the bottom of the seal. The bottom edge of the mirror is in line horizontally with the sunvisors in the down position. I hope that made sense.
72 C20 Longbed 05 1500 Z71 Last edited by sleepertruck72; 02-09-2009 at 08:24 PM. |
02-10-2009, 05:52 PM | #12 |
Are any of these measurements on origional windshields.I'm getting measurements of 2.5" to 3.5" just wondering which one is correct for an origional mirror mounted on an origional windshild.Does anyone have the origional measurements?Thank you.
02-10-2009, 06:19 PM | #13 |
The Factory assembly manual may have the proper location you are looking for.
72 C20 Longbed 05 1500 Z71 |
02-10-2009, 07:36 PM | #14 |
I just checked the factory manual and it doesn't show.
02-10-2009, 08:03 PM | #15 |
on the inside of my windshield from the bottom of the rubber seal to the middle of the piece that mounts to the glass it is 3 1/4 inches. Not sure if this is stock or not but my windshield looks at least 30 yrs old so it may be.
