Old 12-10-2002, 12:35 PM   #1
85Silverado
85Silverado's Avatar
Question Heat Riser
Does anyone know if the Heat Riser (valve in passenger side exhaust manifold near flange) sticks closed or open when the vacuum line to it is disconnected or in my case gone? Thanks for any info
85Silverado is offline   Reply With Quote
Old 12-10-2002, 12:42 PM   #2
J-Spec C10
Whats this wire for?....
J-Spec C10's Avatar
In my truck, it was gone too. I had an exhaust shop check it and weld it in the open position. As for the position it stays, it kinda flaps around a bit.
IMO when the vacuum is applied the diaphragm should pull up on the rod right? So up should be open.
Good Luck!
Kyle
CANADIAN CONNECTION
'82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders
J-Spec C10 is offline   Reply With Quote
Old 12-10-2002, 12:47 PM   #3
85Silverado
Mine feels like theres some spring tension. I went out to move it and it went back to wide open or closed. Could that just be the vacuum diaphragm giving the tension?
Paul D.
'78 C20 Scottsdale
350ci
3 speed with granny gear
14 bolt rearend
My trucks are "Car-Guy safe".......which pretty much means death trap in the hands of a normal civilian.
Old 12-10-2002, 12:49 PM   #4
swervin ervin
You get what you pay for
swervin ervin's Avatar
The valve opens with with a built in spring. When the engine is cold, vacuum which is routed throught the TVS closes the valve. As the engine coolant warms up, it slowly shuts off vacuum going to the valve, allowing it to open with the spring pressure.
So, if you have no vacuum going to it, it should be open all the time.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 12-10-2002, 12:55 PM   #5
J-Spec C10
J-Spec C10's Avatar
theres the difference, I had no rod on mine, and the spring was broken.... the flapping noise drove me crazy!
Kyle
CANADIAN CONNECTION
Old 12-10-2002, 12:57 PM   #6
85Silverado
Nuts, I was hoping it was closed. That pretty much means the weird noise coming from over there is more then likely a knock then.
Paul D.
'78 C20 Scottsdale
350ci
14 bolt rearend
