diy4x engine crossmember
i need a new engine cross member and motor mount set up for my 68 k10 seing as the original is all cut up
has anyone used diy4x's engine crossmember on a 67-68? how easy does it install? and has anyone had any problems with it? thanks alot nate
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
Re: diy4x engine crossmember
It's a breeze to install.
I agree with grendal on the installion and it looks better and stronger than the old factory one. You won't be dissapointed.
alright thats what i wanted to hear, thanks
i will be ordering that sometime this week along with a bunch of new suspension parts nate
Easy install but there were a few issue's with oil pan clearance early on, just make sure to run a stock pan.
...or contact DIY to make sure the one your using will work. |
looks sick!!! cant wait to get my crossmember ordered.
Mine was missing hardware and i had to shim it because there was large gaps between the upper and lower frame C. I could have sucked it down with the bolts, but i didn't want to put undue stress on the frame. Also, if you have a spare motor on a stand, bolt the new motor mounts on to the motor, and then bolt the crossmember on them to check fit. It easier to slot a hole now, then when its in the truck. The crossmember moved my motor to the driverside a little, and up on the pass side a little. I brought it back down with the frame shims. I called Kurt twice and left messages. I got no responce.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
Can someone fill me in, I just located a '71 frame and it's missing the front crossmember.
Anyone have a link for this cross-member replacement if that's what it is ?? Thanks !! |
http://www.diy4x.com/engine.htm
thats the link its a replacement and upgrade i acctualy went a different route and kept my eyes open on the parts board for one
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) Last edited by drivethechevy; 05-01-2009 at 11:30 PM. |
![]() Join Date: Apr 2008
so i put one in my truck and have loved it so far. after i put the new motor in i had to pull the oil pan and the mount worked great. was able to leave the motor in the truck and pull the pan!!
