Need advice on how to repair rust holes in bed floor
Hello everyone, I've recently started a restoration on my 69 Long Fleet Side and after sandblasting the bed floor I found two spots about 1 foot x 1 foot square that have numerous small rust holes. ( most likely where the PO had a tool box or fuel tank mounted) I had a piece of a patch panel ordered from LMC that I got from a friend, however it's too thin of sheet metal, and the height between the peaks and valleys of the surfaces is too shallow. I ordered another patch panel from another vendor, and it is not much better. Has anyone had any luck finding a good aftermarket panel for repairing a bed floor? I've attached a photo of the worst spot that need repairing and also was wondering how others have fixed similar rust spots. Any suggestions would be greatly appreciated.
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
Mean Buzzin' Half Dozen
Re: Need advice on how to repair rust holes in bed floor
You can buy patch bed panels. There like 2' x 2' I think and you just cut out your part that has holes and weld in the patch panel.
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale) 1967 C10 SWB Dylan |
#3 | |
![]() Join Date: Apr 2004
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht Last edited by hotrodhomi; 02-04-2009 at 02:17 AM. |
You obviously do not like the repop patch panels,,,,I would suggest going to the junkyard and finding a decent bed floor and cutting a patch panel from it. I'm not sure if the later square body beds have the same floor depth/peak as the 67-72 floors but it's worth looking at.
The other option I would suggest is to find somone with a sheetmetal brake and make your own patch panel. Getting that many bends in one piece with a brake will be really tough, next to impossible, but you could probably make several pieces containing one ridge and one valley per piece. Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub Last edited by sick69; 02-04-2009 at 02:54 AM. |
#5 | |
Damn Yankee
You should be able to get one from Mike's Bump and Grind right there in TX Last edited by jb4short; 02-04-2009 at 08:30 AM. |
The Panel I got was the 1967-72 Fleetside steel bed floor patch 48" x 16" and it was made by Key Parts. I'm not sure who made the one from LMC. Other the the two small sections with rust hole my bed floor is in really good shape, has anyone had any luck with just welding them up?
Do you plan on getting the bed lined? If so, Line-X can fill in holes that size.
Goodmark has parts in their catalog to fill in spots like these.
I saw them while browsing the catalog. |
#9 | |
Damn Yankee
I wouldn't suggest covering it until it's fixed. That is just masking the problem. If you have never tried to weld a rust hole,,,,you will soon find out that 1/4" hole will turn into a welded glob that looks like a spider with 20 legs!
Check out the Tri-Pro pieces,, I used a couple patch panels of theirs I got from a friend and they were great quality. If your still sketchy of the repops cut a patch panel out of another bed. Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
I'm actually doing a frame off restoration of my truck, and the bed is the first place I decided to tackle. I don't want to take any short cuts and don't want to use aftermarket parts if the quality is bad as I only want to do it once. I've made some phone calls today and think I can get a piece cut from a doner Bed. I going to go take a look at it this weekend. Thanks for all the suggestions.
I've attached a few pictures of the progress so far.
#13 |
Burnouts are therapeutic
can't you just flush it up to the top side ? are you planning on under coating? if so it would hide most of the uneveness.but the donor patch will probaly work best
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
#14 |
find someone that just shortened their bed and see if they will help you out...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#15 |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
In the pursuit of shameless self promotion, I was forced to make 2 beds from one. It was a mess & a ton of work. See my pain here:
http://67-72chevytrucks.com/vboard/s...d.php?t=138385 It turned out pretty good considering...
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
#16 |
Today I was able to locate and cut out some patch panels to repair my bed from a donor bed at a local boneyard. After about an hour, 3 broken jigsaw blades, and almost burning up a harbor freight cutoff tool I was able to get the 2 pieces in the attached photo.
#17 |
I also took this photo to compare these patch panels with the aftermarket piece. I alligned them both at the green line, and it's easy to see how off they are at the red line. The depth of the piece from peak to valley is also not as deep as the original stamping but it probaly cannot be seen from this photo.
#18 |
The patch panels are now welded in place, and the center brace has been replaced. a little more shaping with the grinder, and it's done.
#19 |
Sweet deal man, wish I saw this before buying that paych panel.... HORRRRRIBLE bends. What a waste of money! Now on my quest for a doner!
#20 | ||
"I ain't nobody, dork."
Looks workable to me. Tack and hammer, tack and hammer, tack and hammer. ALL patch panels need tweaking to fit properly.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#21 |
![]() Join Date: Jul 2015
holy 8 year old thread batman!!
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
