Old 02-03-2009, 11:26 PM   #1
73chevyman
73chevyman's Avatar
Question need help
here's the problem. I'm stuck on what it could be. the truck idles fine but when you hit the gas the carb starts popping. Carburetor is a Edelbrock Performer 1407 all the 2 vacuum lines are hooked up correctly the timing advanced is on the driver side vacuum port the PCV Valve line and thats it. the idle mixing screws i read up on them were is a good startng point on them. now the poping could it be 1 lack of gas,2 out of timing, or 3 float out of adjustment. I noticed that it seems to be running rice thank for the answers
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
