Tips Needed: Clutch Install
Alright folks,
You may remember a few weeks back I posted stating I was having issues shifting, and a few days ago posted about my clutch completely failing. Well, I'm moving forward now and have ordered my new clutch kit, complete with everything needed for a fresh, flawless setup. As far as the installation goes...that comes as the job me and friends will tackle this weekend. However, we are attempting this in my driveway [obviously no car lift], under the truck pretty much for hours...trying to get my beast moving again. Any tips or advice, anything I should be aware of for a clean installation? I appreciate it! Thanks in advance |
Re: Tips Needed: Clutch Install
Take the time and have your flywheel resurfaced before installing the clutch. Its a time consuming job if its your first time. Just disconnect the Battery, remove the starter, Drive shaft, crossmember ( if you have one), clutch linkage, 4 bolts for trans, the 8 or so on the bell housing. Then the clutch and then flywheel. If you have an old yoke stick it in the rear of the trans so you dont get gear oil everywhere. Also change the pilot bearing in the end of the crank. then reverse the process and go go go. Good luck. Ive got 2 flywheels so I keep one surfaced so I have done the turn around in about 4 or 5 hrs.
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
![]() Join Date: Sep 2005
![]() 1. Block the wheels 2 disconnect the battery 3.remove the driveshaft 4. remove the starter 5. remove 4 bolts holding the transmission tot eh bellhousing 6. support then engine (i do this with a block of wood and floor jack 7.remove 10 bolts holding bell houseing(8 bolts to engine,2 thought the crossmenber) 8.Remove clutch ( remove and replece polit bushing 9. reinstall resurfaced flywheeel. 10. reverse all above step i have done this in as little as 3 hours
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Active Member
![]() Join Date: Jul 2007
The key is to plan it carefully before you start.
As I got older the most important thing I did was to rent a transmission jack from a rental place. Makes it almost effortless. Also, don't forget a good quality clutch installing tool to aline the clutch plate. I used a cheap plastic one once and it was worthless. A solid one is better. I have an input shaft of an old transmission that I use. Other than that, it's pretty much as smoked68 and truckdude239 said. |
classic=of recognized value
If you have a floor jack you can get an adapter like this for pretty cheap: http://www.jcwhitney.com/webapp/wcs/...atalogId=10101
I have never rented a transmission jack, so that may be cheaper. Guess it depends on how many time you think you will use it. |
You should use wheel chocks weather you're on a flat surface or not."SH!T HAPPENS" Better to be safe than sorry. Set your park brake also. Like to hear about you driving it rather than laid-up and hurt.
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
read your service manual and become familiar with the proper steps in installing the clutch and proper adjustment procedure // just go step by step the way it's listed and you won't have a problem
You didnt say weather it is a 3 speed or 4 speed. I gather its 67-72. You dont have to pull the bell housing on these. Just pull the trans. out & remove the clutch from out the bottom of the housing. Then you can pull the flywheel out too if you are going to have it surfaced. Sometimes the flywheel wont quite clear. You can grind a little groove in the houseing to get it out. With a 3 speed this is the easiest clutch job you will ever do.
