Relocated Fuel Cell
So I am installing a fuel cell under the bed, does this mean I need to have an external safety kill switch sticking out the back?
mini truck racer
Re: Relocated Fuel Cell
I believe the kill switch is required with battary relocation only .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 02-04-2009 at 07:31 AM. |
Battery relocation is a good idea also!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Yes battery will be located back there sometime soon. :P thanks guys
here's where i relocated my battery. i was told that i can put vasaline or something on the battery and the stainless box, then after i race it i just wipe it off. I put it on the outside of the frame so when i get my stainless tank i won't have to move anything.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
Looks nice, but Im not sure about having it exposed to the tire like that....... what is the vaseline for?
I had one mounted in the same area!
Dr. Frankenstein
what did the track techs think about that? im assuming the low and back is to get perfect weight distribution
I Wanna Go Fast!! |
Ya, was it fine through tech? So I don't need a kill switch until I move the battery?
Dr. Frankenstein
nope no kill switch till battery moved....
I Wanna Go Fast!! |
it's behind the tire which is safer incase of a leak. Plus i didn't want it inside the bed because i didn't want to drill a hole for a shut off switch through my bed side or tailgate. The vaseline helps with making it easier to clean. I would think you could have more problems through tech with the battery in the stock location because of a leak being right infront of the front tire. But i never had a problem with either.
