Old 02-04-2009, 11:12 AM   #1
Sinister
Between Trucks...
Sinister's Avatar
Question C-notch on a 3/4 ton
I somehow remember somebody who put a c-notch on a 3/4 ton saying he had some issues with fit due to the frame. I think it was somebody from California. Any info appreciated.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-04-2009, 01:01 PM   #2
pmpislander
Re: C-notch on a 3/4 ton
would like to know myself, seeing as i will be doing it after while on my 3/4.
pmpislander is offline   Reply With Quote
Old 02-04-2009, 01:51 PM   #3
Hart_Rod
Hart_Rod's Avatar
I used the CPP bolt in notch on my 3/4T frame and had only minimal issues as fars as fit.
Hart_Rod is offline   Reply With Quote
Old 02-04-2009, 04:35 PM   #4
pmpislander
do you remember where the problem areas were? maybe something that we can prepare for before we start the notch?
Old 02-04-2009, 05:53 PM   #5
Hart_Rod
Hart_Rod's Avatar
I think there were just a couple extra rivets to drill out. The only real difference between a 1/2 T frame and 3/4 T frame is the extra bracing in the rear part of the frame, at least as far as I know.
* This applies to a 3/4 T frame with TRAILING ARMS not leaf springs.
Check this link out....
http://67-72chevytrucks.com/vboard/s...200387&page=10
Old 02-04-2009, 06:32 PM   #6
jwn1975
I put one in my 70 3/4 ton. CPP brand. No issues at all. I welded mine in though. Use some big c-clamps to hold everything in place.
jwn1975 is offline   Reply With Quote
Old 02-04-2009, 09:00 PM   #7
Sinister
Between Trucks...
Sinister's Avatar
I have another question for you guys. I have an Eaton HO52 rear end, will one of those adjustable panhard bars work with it?
What about shock relocator kits?
Beat it to fit,
Old 02-04-2009, 09:07 PM   #8
Hart_Rod
Hart_Rod's Avatar
I'm not sure. I changed mine over to 1/2 T suspension.....
