Old 02-04-2009, 01:48 PM   #1
rddaves54
rddaves54's Avatar
side trim question
I have replaced my bed and was wondering how to drill the holes needed for the trim the new bed does not have any.
Is there a pattern or something that allows the holes to be straight, the correct size, and distance from each other that I could use?
I would like to do this myself but I do not want to miss it up.
rddaves54 is offline   Reply With Quote
Old 02-04-2009, 03:39 PM   #2
wHATANERD
wHATANERD's Avatar
Re: side trim question
You can also get adhesive clips and would not have to drill any holes.
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 02-04-2009, 06:35 PM   #3
jwn1975
Where do you get the adhesive clips?
jwn1975 is offline   Reply With Quote
Old 02-04-2009, 06:42 PM   #4
oldno7
oldno7's Avatar
I was asking the same ? afew days ago. The previous owner stripped everything. I'll I got was that the holes were 3/8.
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am.
oldno7
oldno7 is offline   Reply With Quote
Old 02-04-2009, 08:28 PM   #5
wHATANERD
wHATANERD's Avatar
LMC has them, The upper clips are PN #30-1652 and the lower is PN #30-1655. Hope this helps.
Old 02-04-2009, 08:33 PM   #6
leddzepp
Moderator
leddzepp's Avatar
I have heard that the adhesive clips do not hold the moulding very well....the moulding ends up sticking out away from the body, and not pulled in tight as it should be.
leddzepp is offline   Reply With Quote
Old 02-04-2009, 09:02 PM   #7
chipflyer
chipflyer's Avatar
Here you go.
http://outintheshop.com/trim.html
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 02-04-2009, 09:39 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
Just measure your old bed sides. That is what I did.
I would use threaded clips front and rear and stick on in between...
LockDoc
Leon
