Old 02-04-2009, 05:56 PM   #1
jmedero
jmedero's Avatar
frame mount brake booster
Does any one know if one of these kits have been done or if it can be done? I know anything is do'able but what do you guys think.
jmedero is offline   Reply With Quote
Old 02-04-2009, 06:16 PM   #2
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: frame mount brake booster
Looks like a set-up similar to an IMCA Modified, where there is no original firewall for it to be mounted.
Anything is possible!
Joey~AP is offline   Reply With Quote
Old 02-04-2009, 08:56 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Did you check out the right angle one in the suspension section? It puts it under the dash. The only reason I wouldnt run one like you posted is that with lowering, which I always do, it would crowd an already tite spot when you consider your exhaust has to tuck up...my first thought, anyway.
If its 4wd or stock hite, it would work fine and definately clear up the firewall.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-04-2009, 10:02 PM   #4
badblu97
Double 6's
badblu97's Avatar
The original poster of this is a good friend of mine, and we are looking to do about the same thing. He has a 65, but Ive got a 83, mine is laying frame with a 3" Z and 2" spindles, and his is just getting started, and I am trying to convince him to rocker his, so help me out on that! We both want to clean up the fire wall. He is doing a front suspension conversion to the 80's style, so we will both have discs front, and disc conversion for the rear. So all in all, we want good braking, and a clean firewall...thanx for all of your input!
protrash, saw the one you are talking about, problem solved! Thanx!
badblu97 is offline   Reply With Quote
Old 02-05-2009, 01:10 AM   #5
protrash64
protrash64's Avatar
.....cool!
Old 02-05-2009, 07:25 PM   #6
jmedero
jmedero's Avatar
found an electric race unit... very small and would work... but $900 bucks...
lol
Old 02-05-2009, 09:55 PM   #7
bwkennedy
I am doing a similar piece on my 66. I got mine from Scoots Hot Rods in CA. They made it for my truck though. Pretty awesome piece.
bwkennedy is offline   Reply With Quote
