Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 02-04-2009, 07:36 PM   #1
6377toys
C10, C60 parts interchangeability?
First this is my first post here, so forgive me if this is old news. You guys seem to have the answers. I live in a rural area with many old C60 ( C70? )farm trucks around. Will any of the cab and front end parts work on a C10? Many of these big trucks are sheded and see little winter use. I'm just hoping for some useable body parts.
6377toys is offline   Reply With Quote
Old 02-04-2009, 08:12 PM   #2
rookierodbuilder
rookierodbuilder's Avatar
Smile Re: C10, C60 parts interchangeability?
someone has posted a thread with c-60 grilles on c-10s also, I have been able to get a close look at a c-60 and I believe that the hood, grille support, doors and even cab parts are interchangeable on many models. As far as front fenders go, I am not sure though. One thing to be extra careful about would be anything that mounts directly to the frame since the frames were obviously very different between the c-10 and c-60/70 trucks
rookierodbuilder is offline   Reply With Quote
Old 02-04-2009, 08:52 PM   #3
TwiggyTheDrummer
Keep It Simple Stupid.. Nope..
TwiggyTheDrummer's Avatar
As far as I'm aware, much like rookierodbuilder, many parts are interchangeable. There is one series of trucks who's hood is shorter but that's the only exception that I know of. There would probably be a difference in the front fender sizes but those aren't too hard to find because it's typically the hood that rusts out and the fenders are normally fine.
1963 GMC SWB Fleetside in Sunburst Orange Metallic
305E V6 w/ Plaid VC, Powerglide, BOSS 313 20" Chrome Wheels, Kumho Ecsta STX 275/45/R20's, Alpine/Clarion System, Dynomax Exhaust
Old custom classic trucks have soul. Their dashboards aren't plastic, and they've survived both the best and worst of what the 20th century had to offer. For the owners of these trucks, it's often the same story. Through both good and bad times they persevered, until one day they could turn the key and roll up in a customized truck everyone with good taste would admire.Custom Classic Trucks
TwiggyTheDrummer is offline   Reply With Quote
Old 02-04-2009, 10:24 PM   #4
collins10672
collins10672's Avatar
the cab will interchange,but the transmission hump is smaller almost flat in the c60,you would think it would be taller than the c10,but it isn't.the doors are the same,windshield wiper panel,cowl panels,and hood will work.grille will work but you have to use your old grille mounts out of the c10.if you find a c60 lcf(low cab foward)nothing will work.the lcf is the one with the short hood,front corners of doors are cutout for fenderwells.the grille panel,radiator support,inner front fenders,front fenders will not work off of c60 because they are all too tall for the c10 frame.i remember a local lumber company when i was a kid had a whole fleet of 1966 c50 and c60 trucks they used for many years i thought they were cool looking.just my 2 cents worth hope i have been of some help.thank you.
collins10672 is offline   Reply With Quote
Old 02-04-2009, 10:32 PM   #5
daveodom
daveodom's Avatar
Just bought a 1965 c-60 for the same reason. Check out the thread I had already posted:
http://67-72chevytrucks.com/vboard/s...d.php?t=321822
The cab is the same from what I've seen so far. The firewall did look a little different. On those big trucks the engine sits a lot further down in the engine bay than on the c-10's. The hood, doors and heater are the same. The front fenders, inner fenders, grill surround, core support, front bumper are all different.
My 64' c-10 build thread "Carla Marie"
http://67-72chevytrucks.com/vboard/s...d.php?t=319356
My 65' c-60
daveodom is offline   Reply With Quote
Old 02-05-2009, 02:53 PM   #6
502tripower
502tripower's Avatar
Another cool thing about these trucks is though 1965 some were powered with a 348 or 409... This C80 has a 409....
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 02-05-2009, 05:57 PM   #7
rookierodbuilder
NICE! I know where there are several of these trucks rotting in the woods, I may just have to check them out myself. The only problem with these, is they have a scallop removed from the upper lip of the cylinder wall to lower compression unlike the infamous 409's found in many of chevrolet's earliest musclecars. Check out this Hot Rod Article.
http://www.hotrod.com/techarticles/e...ads/index.html
Old 02-06-2009, 02:12 PM   #8
502tripower
We are getting a bit off topic so I will start a new thread with this subject. Here is a truck block with the relief cut that you spoke of.
98' FXD
2002 2500HD
Old 02-06-2009, 08:52 PM   #9
6377toys
Thankyou all for your replys. It's going to help me when I start looking again after the snow melts. 502tripower your 348/409 idea is a great one, didn't even think of that.
Old 02-06-2009, 09:17 PM   #10
TwiggyTheDrummer
Man, Florida's moisture has messed up many trucks that I could use for parts, but I'm quite glad that I can easily go look for parts at anytime of the year.
Old 02-06-2009, 10:13 PM   #11
TimE
Hey Y'all!!
TimE's Avatar
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 03-17-2009, 02:12 PM   #12
shrunken66stroker
shrunken66stroker's Avatar
I'm looking for a C-60 grill if there's an extra one floating around out in the woods somewhere.
shrunken66stroker is offline   Reply With Quote
Old 03-08-2016, 12:37 AM   #13
88k5jimmy
Reviving this post a bit. Has anybody swapped a 1964 C60 seat into a 1964 C10? Does it utilize the same bolt hole locations?
88k5jimmy is offline   Reply With Quote
Old 03-08-2016, 09:01 PM   #14
VictoriaHardware
VictoriaHardware's Avatar
Bench seats are the same.
VictoriaHardware is offline   Reply With Quote
Old 07-17-2017, 08:21 PM   #15
88k5jimmy
Would like to get everyone's opinion on the below pic. Please confirm this is not a LCF truck and it would swap to a c10 frame, use c10 fenders, et. Will the cab mounts need to be changed to the c10 style to match with the c10 frame? I know the floor will be different and require using a different trans hump but is there anything else that needs to be modified to fit onto a c10 frame, specifically cab mounts, firewall differences?
Old 07-17-2017, 08:29 PM   #16
C10 - C90 Bill
C10 - C90 Bill's Avatar
It is not an LCF, but that's all I can help with.
Although I have heard that the Cab Mounts are different and I believe they are not easy to change.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 07-18-2017, 07:13 AM   #17
All I know is anyone who'd think of raping the engine out of this complete cool classic rig rather than restore to it's original glory is a fool . Open your eyes, that is a cool truck!!
Old 07-24-2017, 07:13 PM   #18
stein_salv
Hi all,
I'm new here... Im sure this has been asked, but im not finding the answers anywhere. Are hood hinges interchangeable between a 68 c-50 and c-10?
Thanks in Advance!!
stein_salv is offline   Reply With Quote
Old 07-28-2017, 08:24 AM   #19
ratskin
Chevy hinges mount in the same location on all from C10 up.
ratskin is offline   Reply With Quote
Old 02-21-2018, 12:15 AM   #20
Evanallmighty
Hey all. I know the fenders on the c60 are different but how hard would it be to make them work on a c10? I know they are taller but could you trim the bottom and they still bolt on to my inner fenders or are they completely different? I love the look of the c60 fenders and think it would be a different look on a c10. Any help is appreciated.
Evanallmighty is offline   Reply With Quote
Old 02-21-2018, 06:09 AM   #21
Gokart Mozart
How good are you with bodywork? Not only are the tops of the fenders shorter, the wheel openings are larger and have thicker fender flares but the inside wheel wells are completely different to fit the latger wheels. Some trucks have wider track so fender flares are wider.
The doors are cut back in the front lower corner to fit the fenders. The cab corners are cut too.
Hmm, wonder would it would be possible to put a C10 front clip on...
Gokart Mozart is offline   Reply With Quote
Old 02-21-2018, 09:55 PM   #22
stsalvage
Scrapper 1
stsalvage's Avatar
Not to sound stupid witch it will be.But I'm looking to invest into 2 of these old chevy trucks from the 1964-66 trucks.I'm not looking to keep the factory engines in them.I want to Up date to modern LS or Duramax.What are the pit falls of running these types of engines in these old trucks.
I'm looking to run hydro boost brakes Run the newer power steering box AC and run the Allison 6-9 speed.
My question's are can i make the 1980 and up front Ibeam work in my older truck cus i want to run disc brakes.
Do i need to update the rear end for the automatic trans or can i just use the one that came with the truck.it will be check cleaned and fixed if needed.
Would it do any good to run a Air bag system under the truck for handling and comfort.Just asking Questions
stsalvage is offline   Reply With Quote
Old 11-17-2019, 10:35 PM   #23
STPETEBLUE
STPETEBLUE's Avatar
Where, in Florida, can you find these trucks? The ones I'm finding are in the farm belt, nowhere near Florida.
Daily Driver:
2005 Chevrolet Silverado 3500 Dually 6.6L LLY Duramax Diesel and an Allison 5 Speed
Currently looking for an Action Line truck, specifically 1969-1970, in very good condition. Longbed only, step or fleetside, or flatbed if C30. Must be unmolested (not modded).
STPETEBLUE is offline   Reply With Quote
Old 01-11-2021, 03:43 AM   #24
GIJoe2112
GIJoe2112's Avatar
I have a 1968 C-50 LCF (low cab forward) and the hood hinges are NOT the same. Beware. I don't know about non-LCF trucks.
GIJoe2112 is offline   Reply With Quote
Old 03-25-2022, 08:22 PM   #25
Zachry302
Hello all. I have been trying to do some research on C60 trucks. I currently have a 1969 C60 dump truck. As of yesterday I was able to fire it right up and get the brakes air brakes to work. My cab is pretty far gone. However I have stumbled upon a 1970 C60 donor cab. My question is will the 1970 cab swap over to the 1969 C60 frame. I have been putting endless search cues throughout Google to find this answer, and I find some information to answer my question. But I was just curious if anyone has the definite answer. Also was there a certain year that these cabs would interchange with no problems. Thank you all!
Zachry302 is offline   Reply With Quote
