Old 02-04-2009, 08:46 PM   #1
Hawker7
Boot on Brake Power booster
Anyone have a picture on how the boot fits on the power booster? My boot dosn't seem to be long enough to fit all the way down. The metal ring that goes around the boot seems to big also. Any ideas?
Hawker7 is offline   Reply With Quote
Old 02-04-2009, 09:17 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Boot on Brake Power booster
Looks like the wrong boot. The one for the booster should have a bunch of holes. At least mine do. I'll look for a pic.
68gmsee is offline   Reply With Quote
Old 02-04-2009, 09:41 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Here's a pic of the boot installed. I think I got them from GMC Paul. Looks like you're also missing the metal plate that hold it in place. It's the silver looking piece.
Old 02-04-2009, 09:47 PM   #4
Hawker7
I took a picture of the old boot before I threw it away, and it looks like the one I got. I just don't have it anymore to compare sizes. I have a big metal washer that goes on the end, but your boot looks much different. Does anyone else have any pics of their setup? Where there different setups from the factory?
Old 02-05-2009, 03:26 AM   #5
jablack
Classic Chevy Recycler
jablack's Avatar
Looks like your boot just fills the hole on th firewall.
2004 Chevrolet Trailblazer EXT
1970 Chevrolet C50
1979 Chevrolet C30
Need another 67 or 68 soon...
jablack is offline   Reply With Quote
Old 02-05-2009, 03:26 AM   #6
jablack
jablack's Avatar
Looks like your boot just fills the hole on the firewall.
1970 Chevrolet C50
1979 Chevrolet C30
Old 02-05-2009, 11:23 AM   #7
68gmsee
Active Member
68gmsee's Avatar
I wonder if someone didn't put a different boot on the truck than what was on the stock booster. That boot in your pic looks like the one that goes on the firewall as jablack mentioned.
Here's a couple of pics of the boots from the vendors catalogs for 67-72 trucks. The one on the left is the booster one.
Old 02-05-2009, 01:25 PM   #8
ERASER5
ERASER5's Avatar
X2
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 02-06-2009, 07:57 PM   #9
Hawker7
I checked tonight and I was sent the wrong boot. The boot fit perfectly on the firewall. What vendors sell the boot with holes that I need? Should I be concerned that my booster doesn’t have that metal plate??
Old 02-06-2009, 09:44 PM   #10
68gmsee
Active Member
68gmsee's Avatar
Basically that boot is just a dust shield and also for looks. Check with GMC Paul or other vendors on this site. They should all carry it.
If you can't find the metal plate at a salvage yard, I bet you could fabricate one easily from a piece of sheet metal. If you need, I can send you the measurements from the one I have.
Old 02-07-2009, 10:16 AM   #11
Hawker7
What does the metal plate do? I assume the plate just sits there and is held on by the hangers? Please send some measurements.
Old 02-07-2009, 11:15 AM   #12
68gmsee
Active Member
68gmsee's Avatar
As I mentioned, it's just to hold it in place. I don't see where it servers any other purpose. The boot on my booster is a tight fit so probably wouldn't even need it if I didn't have one.
Anyway, the plate is rectangular shaped 4-1/8 inch by 4-1/4 inch. Metal looks like stainless and real thin guage. I don't have a guage tool so don't know for sure-maybe 22 guage?
Since the holes are made to fit the bolt pattern it might be better for me to trace the outline of it and send you the pattern. If you want to send me a pm with an address I'll mail you the pattern.
Old 03-09-2009, 07:28 PM   #13
Hawker7
I finally got the boot for my booster but think I might be missing some parts. The ring that was on there originally doesn’t seem the fit the new boot, and I'm not sure what else goes inside the boot? Am I missing any parts in there?
Old 03-09-2009, 08:10 PM   #14
mbgmike
Your not missing anything here are some pics of new booster and boot. You have to pull on the boot to get it over the lip a little. the last picture is just what it looks like it is if you just shove it on.
You are missing the little foam piece that goes there but thats just for more protection from dirt
mbgmike is offline   Reply With Quote
Old 03-09-2009, 08:36 PM   #15
Hawker7
thanks for the pics. There was a washer in there when I took it apart, but I'm not sure what it did. I also see you don't have the metal plate that others have. Was that only on some models?
Old 03-09-2009, 10:35 PM   #16
jablack
jablack's Avatar
hawker7, where did you get the first boot? that one would work perfect for me..
1970 Chevrolet C50
1979 Chevrolet C30
Old 03-10-2009, 05:01 PM   #17
Hawker7
I got the boot from GMC Pauls. I put the boot on, but it looks way too big. The ring I have won't even fit over it. What am I doing wrong?
