tbi tuning
does anyone know where i can get a tune for a tbi setup? looking at converting my 85 to tbi. 355ci .477-480 lift cam. 10.5-1 compression. thanks for the help. JOE
![]() Join Date: Jul 2006
Re: tbi tuning
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
Re: tbi tuning
The guys on FSC told me to get a labtop and $200 worth of equipment and you can sit on your la-z boy and burn your own custom chips all day long. Theres some experienced really good TBI tuners on fullsizechevy.com
But there 73-87 forum over there is not as good as this one ![]()
Mine- '91 GMC RCSB 2wd, 350tbi, 5 speed, 3.42 G80 -Dad/Me Projects/Toys 75 SWB Silverado Factory 454, Th400 87 SWB Silverado 305tbi, 700r4, 2.73's...17.4 @74mph a couple dodge cummins trucks. PLEASE DO NOT MESSAGE ME ABOUT FACTORY TACH DASHES, I AM NOT MY FATHER AND I KNOW VERY LITTLE ABOUT THEM. Thanks ![]() |
Re: tbi tuning
go check out thirdgen.org
1963 Nova Super Sport 454 4 speed 1991 Camaro 350 1980 Chevy Stepside Long Bed 4x4 402 Big Block |
Re: tbi tuning
talk with local guys that have put ECM controld engines in hot rods and find out who's doing theirs and talk with dyno shops and you'll find more and more one name will come up thats how I found the guy thats done mine and will keep doing them
Re: tbi tuning
The guys that program custom "PROM" chips can get it pretty close to your engine specs, but further tweaking can be done by data logging while driving. Then changes need to be done on another prom. It can be a trial and error process.
79 Blazer Cheyenne, 2wd 305 3.42 stock 85 Caprice, TBI converted, new 350 crate motor, Monte Carlo SS Wheels, Bilstein shocks, |
Re: tbi tuning
Remember TBI's usually are MAP sensor driven and not fond of big cams and low idles. But boy are they nice on cold start!
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
Re: tbi tuning
Larger cams (within reason) can be dealt through altering programmed idle parameters. Generally speaking, for a stock speed density system used in 87+ trucks keep cam LSA above 112 deg, with 114 deg being ideal while keeping duration at 0.050 below 214 degrees. Trucks need low RPM torque (to move the weight) and higher duration cams generally produce HP at higher RPMs.
The problem is not just the cam change but that the overall volumetric efficiency of the engine is effected - new cam usually goes together with different heads (porting, aftermarket, etc), free flowing exhaust, alternative intake, etc. The only way to deal with these changes is to tune your combination yourself. There is a learning curve involved, but results are worth every penny. //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
Re: tbi tuning
Everything here was well said. I have heard all good reviews for tbichips.com. Whatever you do, don't buy a "generic" chip that you can buy from a mail order (jegs, summit). You need a chip burned for YOUR application. One chip can't possibly be fit for every vehicle out there.
I have an 87 with a high mileage 305. I have since added true dual exhaust, k&n drop in filter, injector pod spacer, and tbi spacer. The exhaust and spacer are what made the most noticeable increase in torque. I think I need to add an adjustable fuel regulator though to bump up the pressure and a chip. I'd love to add a cam and heads next since the truck seems to have good torque/throttle response but falls flat on its face in the high rpm.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch |
#10 | |
Re: tbi tuning
Finally, EPROM tuning will extract the overall performance that otherwise can not be realized by leaving stock factory EPROM parameters or by simply relaying on mail order tune. To perform your own tuning requires investment of time and equipment. //RF
#11 | |
Chevys Kick A$$
Re: tbi tuning
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
Re: tbi tuning
here is my compination 355, 10.5 compression, vortec heads, comp cams x treme energy 262 cam. .477-.480 lift cam 112 degress of seperation. edelbrock intake,flowtech headers with 2 1/2 exhaust down to 2 c hamber flowmasters. also what is lsa in the above response? thanks for all the great info. JOE
#13 | |
Re: tbi tuning
Vortec heads will not require as much timing as your original heads and with all other speed goodies that you have no stock bin (EPROM contents) will run your engine properly. Did you update Vortec heads for higher lift???? One point of reference for bin files is Moates.net in the 1227747 $42 section. There are several posted bins there that were developed to run engine combos very similar to yours. With enough fuel and proper tune your combo should be in 300+ HP range. Expect to idle around 700 RPM with a hint of lope. My advise - learn how to burn your own chips or get EBL board from Dynamic EFI which allows real time changes - no chips required. http://www.dynamicefi.com/ EBL makes tuning a much simpler task (I have EBL flash in my C20) well worth it. //RF
